| Authorized Vendor Car: 01 Subaru WRX STi Spec C Fav Mod: Coming Soon Posts: 3,954
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Sale, Sale, Sale on all engine components! Dont miss out on STi TGVless intake manifolds back in stock! Limited quantities available so act now. Also Group N engine mounts back in stock. IHI VF22 on super sale this month. STi V8 Intake Manifold Back In Stock!!! ![]() The best solution for TGV Deletes for the 2002-2005 WRX EJ20 is the JDM Spec C manifold. Not only does this manifold look amazing, it deletes your TGV's thus improving performance (you will need some form of engine management to turn off the CEL)*. Airflow to the engine is improved ~20% and the stock top feed injectors and fuel rail is retained (compatible with aftermarket injectors / rails) Included is the CNC machined Gruppe-S fuel rail adapter to allow this all to happen. Sold Out JDM STI TGV Deletes ![]() For 04+ 2.5 Cars only. Don't waste your time welding up your stock TGV housings (and testing for leaks). Go OEM! Increase airflow by ~20% with the JDM OEM TGV deletes for a limited edition STI car. They are BRAND NEW. Get rid of the pesky stock TGV's with the JDM housings. They are bolt on parts* and compatible with the factory intake manifold. You will need a form of engine management, such as the Cobb AP to remove the check engine light. Pricing is for a pair. $199 Shipped IHI VF22 Turbo 375HP Package ![]() The IHI VF22 is a DIRECT bolt-on upgrade for your WRX. The turbo makes big power! The VF22 adds mid-range punch as well as vastly-better top-end performance vs. the factory Mitsubishi TD04. Typical gains are 20% in peak horsepower, and a whopping 30% gain in torque over the stock turbo at redline! BIG compressor housing means lots of nice cool air, even at relatively high (20 psi+) boost pressures. - IHI VF22 Turbo - STI 565cc Injectors, - Walbro GS342 Fuel Pump w/ setup kit IHI VF22 Turbo 375HP Package $1375 Shipped Now $1299 Shipped VF22 Turbo $799 Shipped Now $749 Shipped MHI 18G Turbo 400HP Package ![]() The new MHI TD05H 18G turbo for Subabru WRX. With 7cm2 turbine housing, also included are water lines and oil drain line. This high-powered upgrade is good for 400 HP and flows 600 cfm! 1yr warranty. This turbo is a direct bolt-on for all GC8, GDA, GDB EJ20 turbo engines. -MHI 18G Turbo - PE 650 or 800 cc Injectors, - Walbro GS342 Fuel Pump w/ setup kit MHI 18G Turbo 475HP Package $1250.00 Shipped MHI 18G Turbo $749.00 Shipped ATP GT30 Turbo 450HP Package ![]() Xtreme EVO Killer System -GT3076R/ or GT3071R Turbo -Hydra EMS -Perrin 3" Turbo Inlet Pipe -Denso 860cc Injectors -Walbro 255 lph Fuel Pump - w/ Setup Kit $3999 Shipped to the door. Pro Max System -GT3076R/ or GT3071R Turbo -Cobb Accessport -Perrin 3" Turbo Inlet Pipe -Denso 860cc Injectors -Walbro 255 lph Fuel Pump - w/ Setup Kit $3199 Shipped Street System -GT3076R/ or GT3071R Turbo -Cobb Accessport -Denso 860cc Injectors $2950 Shipped ATP GT3076R/ or GT3071R Turbo $1799 Shipped Add a Cobb Accesport to any Turbo Combo For Ultimate Tunning ![]() The AccessPORT reprograms your vehicle's computer to optimize the air/fuel ratio and ignition timing, increase boost, remove the speed limiter, and more for performance results you can instantly feel! Pm For Super Low Price For Maximum Turbo Efficiency Dont Forget to Add a Spearco Top Mount Intercooler ![]() Spearco TMIC Kit 02-07 WRX Free Gruppe-S Intercooler Y-Pipe for WRX PM For Price Spearco TMIC Kit 04-07 STi Pm For Price In Stock Ready To Ship Gruppe-S Equal Length Exhaust Manifold Free Helix Up-Pipe ![]() Constructed from T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. Dyno proven to make up to 8hp and 12 ft-lbs of torque. The design of the Gruppe-S equal length manifold increses boost response. Spool up time is decreased incresing boost pressure at lower RPM's. Due to the exhaust pulses now being paired together the lumpy boxer sound is lost instead a smoother sound is produced. 2.0L Engines Require 2.5L Oil Pan For Manifold Clearance WRX/ Legacy/ Forester/ STi 2.5L $599 Shipped WRX/ Forester/ Legacy 2.0L $699 Shipped (STi Oil Pan Included for Propper Clearance) New Helix Up-Pipe ![]() - 44mm id - stainless steel construction - robotic tig welded flanges - machined flanges $125 Shipped Gruppe-S Unequal Length Manifold Ceramic Coated ![]() The Gruppe-S manifold is a 4 to 1 unequal length manifold. It will retain your boxer rumble and features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. This header is dyno proven to make power; it will not lose power or torque in 2.5L applications anywhere in the RPM range. 2.0L motors will lose some low-end and mid- range power to gain more high-end power and torque. The more modified your vehicle is, the more pronounced the gains from these headers will be. The outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly $575 Shipped This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by Gruppe-S; 03-31-2008 at 06:47 PM. |
| | #2 |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Helix Down-Pipes ![]() Non Catted $199 Shipped Free CEL Fix Catted Sold out. ETA End Of April Combo up your Helix Downpipe with any of these awesome exhaust ![]() Helix DP/HKS Hi-Power- $699 Helix Catted DP/HKS Hi-Power- $769 Helix DP/HKS HKS Carbon-Ti- $775 Helix Catted DP/HKS HKS Carbon-Ti- $899 Helix DP/GReddy TI-C- $640 (Backorder until mid March) Helix Catted DP/GReddy TI-C- $765 (Backorder until mid March) Helix DP/Blitz NUR Spec- $699 Helix Catted DP/Blitz NUR Spec- $825 Looking for power without all the sound? Add one of these "Quiet" exhaust with any Helix Downpipe ![]() Helix DP/A'Pexi World Sport- $625 Helix Catted DP/A'Pexi World Sport- $750 Helix DP/Apexi WS NOIR- $675 Helix Catted DP/Apexi WS NOIR- $799 Helix DP/GReddy SP2- $699 Helix Catted DP/GReddy SP2- $825 Helix Dp/Tanabe Medalion Touring- $699 Helix Catted DP/Tanabe Medalion Touring- $825 Awesome Turboback Combos Only a Few Left at these Unbeliveable Prices HKS Hiper/ HKS Downpipe Free CEL Fix ![]() $599 Shipped HKS Carbon-Ti/ HKS Downpipe Free CEL Fix ![]() $775 Shipped RSR Ex Mag/ HKS Downpipe Free CEL Fix ![]() $799 Shipped STi Engine Mounts Limited Quantities In Stock ![]() The STI "Group-N" Engine Mounts are designed to reduce excessive motion of your motor during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine. $99 Shipped Cusco Engine/Tranny Mount Combo ![]() $259 Shipped Engine Rebuild Kits ![]() EJ20 Engine Combo/ EJ25 Engine Combo -CP (std) or (+020) Pistons -CP Piston Rings -Helix Forged Rods -Coated Race Bearings $799 Shipped |
| | #8 |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Closing Thread Guys Click Here For Updated Specials BC Cams Now Available-Cosworth InStock-Unequal Length Manifolds-Turbo Back Combos$625 This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
