Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Closed Thread
Old 03-13-2008, 07:05 PM   #1
Default Group A Lightweight Pulleys
Below are at this point Group A Performance's hottest products, there lightweight pulleys. These pulleys have been designed and manufactured by Group A to meet the highest standards in quality and improve the performance of your Subaru. We currently offer 3 setups for purchase, the 2-Pulley set which includes the Lightweight Crank Pulley and the Lightweight Alternator Pulley. The 2nd option is the 3-Pulley Set which adds the Lightweight Power Steering pulley to the mix. Lastly we do offer the Crank Pulley alone for sale aswell.
Contact
Chris - Sales@tougetuning.com
Website - ..::Touge::Tuning::..
Pricing
Crank Pulley Only
$100 Shipped
2 Pulley Package (Crank & Alt) (For those with non Bolt-on or pre-99 Models)
$140 Shipped
3 Pulley Package (Crank, Alt & Power Steering) (For All Bolt-on PS Pulleys, Fine or Coarse teeth versions available now)
$210 Shipped
All Pulleys are Black in color.
Check out Group A's site - /// Welcome To Group A Performance ///
Crank Pulley
* 6061 Aluminum
* Anodized
* CNC milled
* Balanced
* Easy Install
* NOT UNDER DRIVEN
* Uses stock belts for install
* Group A Pulley: 1.5 LB (680 g)
* Stock Pulley: 6 LB (2.7 Kg)
* 4.5 LB Lighter!
* Allows engine to rev easier
* Equivalent of removing 100 LB from the weight off the vehicle
* 12 ft/lbs of torque increase
* Subaru does not use a harmonic balancer so there is no worry about vehicle issues
* Improves Fuel economy
* Helps for heel / toe technique
* Cool Looking
Alternator Pulley
* 100% made in Canada
* 6061 Aluminum
* Anodized
* CNC milled
* Balanced
* Easy Install
* NOT under-driven
* Group A Pulley: 2.4oz (70g)
* Stock Pulley: 5.9oz (165g)
* Improves fuel economy
* 1-2 ft/lbs torque increase
* Cool Looking
Power Steering Pulley - Only fits Bolt-on PS pulley models (99+ N/A and Turbo models)
* 6061 Aluminum
* Anodized
* CNC milled
* Balanced
* Easy Install
* NOT under-driven
* Cool Looking
* Group A Pulley: 8.1 OZ (230 g)
* Stock Pulley: 13.4 OZ (380 g)
You can determine if it will fit your vehicle by simply looking at your stock PS pulley and if there is a nut holding it on you will be fine.
There are two versions of the Power Steering Pulley:
1) Fine Spline
2) Coarse Spline
There is no rhyme or reason to this as Subaru used different Power Steering Pulleys based on what they had available. Please contact us for fitment.
TougeTuning.com is offline
Old 05-06-2008, 09:48 PM   #2
Default Re: Group A Lightweight Pulleys
Bump, all fitments in stock ready to ship out!
Old 07-06-2008, 09:05 PM   #3
Bump, order yours today!
Closed Thread
