Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Engine/Power/Exhaust
Old 12-12-2007, 10:33 AM   #1
Car: STI's ;)
Fav Mod: Coolest Vendor Ever
IWSTI Addict since: Aug 2003
Send a message via AIM to RallySportDirect Send a message via Yahoo to RallySportDirect
Default OkadaProjects PLASMA DIRECT Ignition Coils! The BEST and ONLY coils available!
A revolution in ignition technology!!
FOR ALL 2002-2007 SUBARU TURBO APPLICATIONS! WRX, STI, Forester XT, LGT!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant and C.A.R.B. approved.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Picture of the 1st Graph shows stock ignition, and 2nd graph shows with the coils. As you will notice, the Primary Amperage is almost doubled as well as higher 2ndary ignition, with multiple isolations instead of a weak OEM 2ndary spark.
RE TUNE OF THE VEHICLES ECU IS HIGHLY RECOMMENDED! AS IGNITION WILL NEED TO BE CORRECTED IN THE UPPER RPM RANGE .AS WELL AS BOOST INCREASE DO TO A MORE THOROUGHLY COMPLETE COMBUSTION POSSESS! INCREASE IN UPPER RPM BOOST LEVELS WILL BE NOTICED!
Includes all 4 coils.
Oscilloscope Data
Comparasion of Ignition Secondary current on the same time scale.
OEM
OkadaProjects Plasma Direct Ignition Coils
As you can see, the Primary Ignition Spark is almost doubled, as well as 2ndary Ignition is also multiple re-Ignitions compared to the standard OEM Coils. With OkadaProjects Ignition Coil complete combustion of all Fuel is more likely to occur compared to the stock.
PRICE IS 690.00 SHIPPED!
Pleas call in or Visit the link below to place order!
LINK
Thanks
Kirill
RallySportDirect.com
801-748-4910 ext 1006
RallySportDirect is offline   Reply With Quote
Old 12-21-2007, 04:24 AM   #2
Car: Silver Euro 07 STi
IWSTI Addict since: Dec 2006
Default Re: OkadaProjects PLASMA DIRECT Ignition Coils! The BEST and ONLY coils available!
Nice!
Is that compatible with this?????
RallySportDirect.com - HKS WRX / STi Twin Power DLI II
Thanks
Old 12-21-2007, 10:06 AM   #3
Car: STI's ;)
I would not. As the OkadaProjects will amplify the ignition themselves.
Kirill
Old 12-27-2007, 03:38 PM   #4
Car: STI's ;)
To the top!
Old 01-10-2008, 01:39 PM   #5
Car: STI's ;)
Dont let the stock coils limit the performance of you high HP subaru!
Old 01-10-2008, 01:59 PM   #6
Fav Mod: Carlabs X-brace & RPM brace
IWSTI Addict since: Oct 2005
Any dyno plots of gains on a modded STI? Anything stage II or above would be nice to see.
hoffit is offline   Reply With Quote
Old 01-11-2008, 08:49 AM   #7
Car: STI's ;)
This is off OkadaProjects web site. On a 2.0L
Old 01-11-2008, 08:51 AM   #8
Car: 06 OBP STI
Fav Mod: Snow Tires :)
Send a message via AIM to xerox445
How can they be the best if they are the only ones avail?
xerox445 is offline   Reply With Quote
Old 01-11-2008, 09:33 AM   #9
Car: STI's ;)
As the stock ones cant provide enough secondary spark at high RPM to provide a sufficient burn.
Old 02-04-2008, 05:10 PM   #10
Car: STI's ;)
To the toP!
Old 02-07-2008, 12:20 PM   #11
Car: 06 STi
IWSTI Addict since: Nov 2006
How will leaded race gas affect these coils? Risk of burning out coils like stockers or less of a chance?
Old 02-07-2008, 12:28 PM   #12
Car: STI's ;)
These coils are designed for race use. So they will hold up to harsher used over stock coils.
Kirill
