Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Private For Sale Classifieds > Engine / Drivetrain / Performance / ECU Reflash Units
Old 07-04-2008, 05:53 PM   #1
Car: Silver 05 Wrx STI
Default FS(CT): PPG FULLY BUILT Trans + LSD DIFF + PPG OUTPUT SHAFT
Hey there. Up for sale is a brand new built / rebuilt ppg 5spd.
I had the ppg gears in the case for about 3k miles but just recently had it over hauled and looked at and replaced the synchros and new sleeves. The transmission was having a 5th gear grind before the ppg gears went in and it went away for a little but then came back thats why it was rebuilt/built again.(1000 to rebuild and bring it back to new) The gears looked perfect the rebuilder said. It also has a jdm sti front lsd with upgraded stub axles, also comes with a 3.90 output shaft from ppg upgraded as well that way its a direct swap with a r180 rear diff w/3.90 final drive.
Included:
1-2 ppg strait cut syncro
3-4 ppg helical syncro
Brand new syncros
Brand new sleeves
2004 wrx case w 20k miles on case
Jdm sti front diff w/lsd
ppg upgraded ouput shaft 1 to 1
I paid 5700 for the tranny the first time and another 1800k for the rebuild and brand new output shaft recently so thats 7500 worth in this tranny. Was looking to get 6000 for the complete tranny witch means you get to keep your stock 5spd and get a fully built ready to go tranny with no down time and u save money if you were going to get the upgraded front diff or r180 swap.
The output shaft, syncros, and sleeves are new. Gears only have 3k miles on them and are perfect.
$6000
ctracer911 is offline   Reply With Quote
Old 07-09-2008, 01:27 PM   #2
Car: JBP 04 STI/07 LTD
Fav Mod: Cusco Zero 2E coilovers
Default Re: FS(CT): PPG FULLY BUILT Trans + LSD DIFF + PPG OUTPUT SHAFT
You looking for trades?
cellgeek101 is offline   Reply With Quote
HTML code is On
