Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Private For Sale Classifieds > Engine / Drivetrain / Performance / ECU Reflash Units
Old 06-08-2008, 11:39 AM   #1
Car: 93, 00, 01, 06, 07
Send a message via AIM to imprezarsx
Default FS (WA): Fully Built EJ257, NEW
I just built this block for my 07 STi. Unfortunately I discovered that nobody makes headgaskets thicker than stock for an 06wrx/07sti head. So now it won't work with 07 heads (because factory gaskets are only 0.021" thick) and I need to either put it in my RS or sell it.
This thing is made to spin high (8k rpm) and make big HP (750hp+) with the proper supporting components.
The block:
LA Sleeves 100mm bore
Custom Dish Wiseco Pistons (100mm, .0030 p/w clearance, TriCoated)
Carillo Rods, Factory Length, Modified to add oil squirters,
ARP 2000 Rod bolts- Torqued using Rod Bolt Stretch Gauge (0.0055" stretch)
New Sti Crank- MicroPolished
ACL Race Bearings (.002" rod clearance, .0016" main clearance)
Align honed
Fully Balanced and Blueprinted
Oil galleries modified for high rpm oil stability.
All New Case Bolts
All rotating components were balanced individually then balanced together.
This includes:
Factory Pulley, Pulley bolt, Timing belt drive sprocket, Crank, STi Flywheel and bolts, New STi Clutch
Requires 11mm pump at the least if being used with AVCS heads. No thinner than 10w30 oil for Daily Driving, at least 15w50 Mobile 1 recommended after 3k miles for high HP/RPM.
Requires .030" headgasket minimum. Deck Clearance is -0.004"
Recommend .051" for high lift AVCS applications.
0.040" Gasket for non AVCS applications and high lift cams.
Includes Flywheel/New Clutch/Pulley/Bolts/Drive Sprocket.
$4200+ shipping. Local pickup/delivery Preferred
Will sell without clutch components, but I figured I might as well keep all the balanced components together.
I'm calling Cometic on Monday. If they'll make a custom headgasket for a reasonable price and wait time, I'll just go that route. Otherwise, I already have plans for a different block with longer rods.
imprezarsx is offline   Reply With Quote
Old 06-14-2008, 01:45 PM   #2
Default Re: FS (WA): Fully Built EJ257, NEW
Cometic said 3 to 6 months for custom gaskets.
Still for sale.
Old 06-16-2008, 04:06 AM   #3
Car: 03 STi
Which model heads can be fitted to this block? Would EU/AUS spec 2litre(ej207) sti AVCS heads work?
Hally is offline   Reply With Quote
Old 06-16-2008, 09:33 AM   #4
Car: white 05 wrx sti
Fav Mod: Greddy T67 (25g) Turbo
niccccccccccccccccccccccccccce omg id love to have something like this
jdmwnnb is offline   Reply With Quote
Old 07-08-2008, 08:04 AM   #5
Car: Pearl Wht 07 STI
Fav Mod: SR56 turbo & Rays 18"
Pm'ed you.
STi Str8 Beast is offline   Reply With Quote
HTML code is On
