Old 08-06-2007, 05:44 PM   #1
Car: 07 STi
Default Stage two
I am thinking about going stg2 on my 07 sti
I was thinking about the cobb catted DP and TBE
My question is if I have the DP and TBE installed and for some reason have to flash back to stock is my speedo console going to look like a x-mas tree with all the blinking lights.
Also I have heard that it is best to go catted with the 07 due to creep
any truth to that?
thanks guys
-ed
STInky07 is offline   Reply With Quote
Old 08-06-2007, 06:30 PM   #2
Car: 07 OBP STI
Fav Mod: Sundays and Boxers
Default Re: Stage two
If you are running COBB products there is alot of truth to that. They post all over their website not to do it. In order for them to post something like that, they probably ran into the issue testing the products.
StylesJim is offline   Reply With Quote
Old 08-06-2007, 06:35 PM   #3
Car: 05' OBP STi
Fav Mod: race school
07's= picky
I would recomend a high flow cat TBE to help with boost creep and a tune the same day
mnsubaruboy is offline   Reply With Quote
Old 08-07-2007, 05:18 PM   #4
I thought you needed a catted DP for the 07 as it says on Cobbs forums, however I was told by a reputable tuner that it only applies to the off the shelf Cobb maps. If the car is protuned, catless should not be a problem and it is cheaper.
I have an appointment to have the Cobb Catless DP/accessport and protune on my 07.
lidrew is offline   Reply With Quote
Old 08-08-2007, 05:14 AM   #5
Car: 07 Subaru Satin Whit
Fav Mod: Protuned STG 2
Send a message via AIM to PCGuRu2K
I've read where people with the catless dp w/Protune still get boost creep on the '07s only though. Cobb released a bulletin about replacing the restrictor pill if your going catless which should fix your boost creep issue
PCGuRu2K is offline   Reply With Quote
Old 08-08-2007, 09:15 AM   #6
Car: 07 STi
thanks for the info guys
I have a AP coming in a few days so just wanted to be sure
