Old 07-31-2007, 07:00 PM   #1
Car: 08 Subaru WRX STI
Send a message via AIM to RAE129
Default Green Test Connectors Found Under Steering Column
Does anyone know who manufacturers the green test connectors (both male and female) that are located under the steering column, used to reflash the ecu. Does anyone have part numbers or know where i can purchase a set?
RAE129 is offline   Reply With Quote
Old 07-31-2007, 08:45 PM   #2
Car: 06 WRB STi
Default Re: Green Test Connectors Found Under Steering Column
If you are looking for an easy way to plug/unplug them just leave them connected and place a 2 way toggle on one of the wires.
webcrawlr is offline   Reply With Quote
Old 07-31-2007, 08:55 PM   #3
NIИja
LaMer's daily driven 2006 STI
OR for an 'easier' route, PM Crystal_Impresav .
Old 08-07-2007, 11:15 AM   #4
Car: '07 STi Limited #482
Something tells me that's not a good idea if you are still under warranty...
Old 08-07-2007, 11:40 AM   #5
Car: aspen 2005 wingless
The guys at MZM soldered up a set of pigtails with a rocker switch that can be plugged into any Impreza, it's pretty slick.
Old 08-07-2007, 01:48 PM   #6
Fav Mod: DOM3 Paperweight
+1.
I think the dealer will castrate you.
Old 08-08-2007, 04:33 PM   #7
Car: 2002 WRX Stg2
Fav Mod: External Wastegate
Use a rocker switch. You'll need 2 wires that go from where the rocker switch is, to the green test connectors.
You'll need a way to attach these wires to the switch. This will vary depending on the switch.
At the side of the test connectors, crimp a male disconnect onto one wire, a female disconnect onto the other wire. Plug the disconnects into the test connectors. Done. When the switch is "on", youre in test mode. When the switch is "off", youre not in test mode.
No permanent modifications are done to your car. Going to the dealer? disconnect hte disconnects from the green connectors, and hide the wires w/ disconnects under the dash. If the dealer asks what theyre for, tell them theyre for your hidden garage door opener, which you have removed.
(If you really do want to use the switch for your hidden garage door opener, PM me)
blk rex is offline   Reply With Quote
