Old 06-04-2007, 06:10 AM   #16
Car: 05 obp/gold
Default Re: What is needed for 1/8 NPT OP Sender in Galley plug install?
Originally Posted by STIfreak7
I just did my defi install yesterday and put in an Imperial oil temp gauge (F) in using the subaru galley plug. As I understood the Imperial gauge temp sensor is NPT and the galley plug in BSP. Dont want to sound chincy but I just put the NPT sensor into the galley plug, a dab of blue locktight and a couple wrenches and it went right in, no leaks, works great. I dont see a need to buy an adaptor. Just my .02
that pdf from colder will show you just why this is a bad idea. see page 5, specifically.
gregsachs is offline   Reply With Quote
Old 06-14-2007, 06:37 PM   #17
Car: 04 WRB WRX STi
So, if I have a Defi BF imperial Oil Temp 1/8 NPT all I need is this:
http://www.egauges.com/vdo_send.asp?...Adapters&Cart= part #R7965?
I won't need the Subaru oil galley plug?
I already have the Galley plug. I was also thinking of tapping it. Any comments on that?
Nodnarb901 is offline   Reply With Quote
Old 06-18-2007, 06:06 AM   #18
Car: 03 mbp gga
Fav Mod: 12.9 / 105+
Send a message via AIM to ride5000
i've heard of others doing this too, fwiw.
if there's no leak you're good to go.
ride5000 is offline   Reply With Quote
Old 06-18-2007, 05:20 PM   #19
Car: 06 Yamaha R6 Raven
Fav Mod: NO car payments!!
Send a message via AIM to STIfreak7
I'm agree with the link posted that said what I was doing was wrong, so on a mathamatical level its not the right way to do it. I just checked again yesterday, about 1000 miles on the gauges and still no leak, not like it hurt the car, worked just fine.
STIfreak7 is offline   Reply With Quote
Old 04-28-2008, 07:52 AM   #20
Car: '05 Black Impreza
Fav Mod: Windshield washer cooler
Send a message via AIM to Foxey
Edit: Never mind
Subaru Part Number: 11024AA210 & 037018200
~Fox
Foxey is offline   Reply With Quote
Old 04-28-2008, 08:02 AM   #21
Car: OBP,2005,STi
I know the part number is listed in the NASIOC thread talking about this.
I came across it while I was looking in to doing this but,
I found that getting a sandwich adapter is much easier than pulling parts off to get to those galley plugs.
I couldn't see any reason a quality sandwich adapter and correctly used teflon tape on the sensors is any more likely to leak than an oil filter so I picked up the Greddy sandwich adapter then installed it with my oil pressure and temp sensors during my next oil change.
AllWheelDriven is offline   Reply With Quote
Old 04-28-2008, 08:23 AM   #22
Yes, it might take more work initially, but then I never have to see or deal with it again(at least unless something happens) I just like stuff out of the way, and a sandwich adapter isn't really my cup o'tea. Plus less running of electrical wire
Old 05-13-2008, 03:45 AM   #23
Car: 03 mbp gga
please do not use teflon tape on oil lines. use dope, not tape, to prevent small particles from being introduced to the system. the same goes for fuel lines.
