Old 02-10-2007, 12:56 PM   #1
Car: Slow 05 STi
Fav Mod: Loping Idle
Trader Rating: (12)
Default Every wonder why your Max WGDC only reads 90.2%?
This has bugged me for long enough so I spent the day look into why it does this. There is code in the ECU that limits the max WGDC to 90%. I was able to find it today and will be testing it out shortly. Here is an example and some screen shots: It should be noted that the ECU will not take more than 99.5% inputed into this table...
Old 02-10-2007, 01:32 PM   #2
Car: Slow 05 STi
Trader Rating: (12)
Ok here are the results, and they were quite successful if I might add. The only problem I had was getting it to use enough WGDC since its about 30* outside and my compensation tables kept pulling a ton of WG. The only way I got it to show any results was to park it still and let the IAT temps rise then hit the throttle. Check it out:
Old 02-10-2007, 04:27 PM   #3
I assume they set that to help protect the solenoid from frying.
Old 02-10-2007, 07:09 PM   #4
Car: 05 Subaru WRX STi
Fav Mod: Cobb StreetTUNER
+1
I think solenoids like high duty cycles.
Old 02-10-2007, 11:12 PM   #5
Car: Slow 05 STi
Trader Rating: (12)
Personally I run an aftermarket EBCS so I have no worries about frying it. Honestly me and wolf have been arguing this for a good time, and I am happy to pick up the extra 10% WGDC for an extra 1psi at redline. Oh yea an on some 16bit ecu's I have seen 100% WGDC's before.
Old 02-11-2007, 10:48 AM   #6
Moderator & ECU Tech
Fav Mod: mo boostaz
^ Agreed if you are a DIY guy. I have no worries about frying my GM BCS. I can pick up a new one locally for under $20. So, if it fries, so be it. However, if I can hold more at redline - so be it
Good catch on the WGDC. I guess you are liking IDA Pro
t
Old 02-11-2007, 11:01 AM   #7
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Oh neato...thanks.
Old 02-11-2007, 11:32 AM   #8
Car: Slow 05 STi
Trader Rating: (12)
t
Haha yea, I am finally getting the hang of it. Let me know if you want the xml for that. I like being able to run another 10% wgdc muhaha. When ru going to start your master hacking skills!
Old 02-11-2007, 11:59 AM   #9
I certainly wasn't saying one shouldn't do it, just stating a general note of caution for anyone that wasn't aware of a potential issue.
Old 02-11-2007, 07:58 PM   #10
Car: 06 Evo IX SE
So I take it that this "primary wastegate maximum" is not a modifiable parameter using Cobb StreetTuner?
06stiman is offline   Reply With Quote
Old 02-12-2007, 07:38 AM   #11
Car: Slow 05 STi
Trader Rating: (12)
Nope, neither is this... I will be testing it out as soon as I can get my hands on a 3 bar MAP:
Old 02-12-2007, 08:28 AM   #12
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
t3h ub3r l33t h4x0r! Keep up the good work man.
Old 02-12-2007, 08:48 AM   #13
Ohh snap.
Been waiting for this for a while now. 3bar MAP here we come.
TMS
TheMadScientist is offline   Reply With Quote
Old 02-12-2007, 08:58 AM   #14
Car: Slow 05 STi
Trader Rating: (12)
I just need to figure out the conversion for these numbers... Any ideas as to whether or not it would follow the same logic as the UTEC?
Old 02-12-2007, 09:04 AM   #15
I wouldn't count on it. It might, but I would be VERY suprised if it did.
TMS
