Old 12-09-2006, 06:17 PM   #1
Car: OBP STi
Fav Mod: really quick left foot & anything made my TIC
Default considering defi boost vs. eboost2
I want a gauge that will tell me when I am spiking, and is very accurate. I have started other threads, and searched a lot and have come to the conclusion that defi gauges are just tools that give fairly accurate, but still the measurements are rough. What I believe is accurate is basically what the AP or Tari logging says. For my purpose of making sure I am not over boosting, would you recommend the defi gauge, or the eboost2?
pharo is online now   Reply With Quote
Old 12-09-2006, 07:47 PM   #2
If in doubt, flat out
Trader Rating: (23)
seems kind of like you're comparing apples to oranges.
the eboost is going to give you more accurate boost readings and is also a boost controller. as i'm sure you know.
but the eboost costs more than a boost controller and a defi gauge.
you can log and control boost with the AP and an upgraded boost solenoid (perrin or gm typhoon) and use the defi keep track of your boost regularly/ watch for overboost/etc. this is what i do/would do, it's cheaper.
defi is jst an analog gauge. obviously, you understand this. just posting my thoughts.
Old 12-09-2006, 07:59 PM   #3
Car: OBP STi
yeah, I am just trying to find if the defi is accurate enough to warn me if I am passing 18 psi, so I know to take my foot off the gas. The best case scenario would be if dtec or plx-500 could hook up to a navi screen (like z1 or alpine), and thus make a warning sound if I go over a warning, I don't think thats possible.
A better question might be, can the defi to read as accurately as the AP's live readings?
Old 12-09-2006, 08:01 PM   #4
Trader Rating: (23)
yeah it has peak warnings
Old 12-09-2006, 09:22 PM   #5
Iron Fisted
Fav Mod: Sparco seat
My defi set-up in my evo is very reliable. From what I have seen, the boost readings are very accurate. Also, on the defi link control unit, there is a "peak warning system" or something of that sort (don't know much about this because I haven't had to use it *knocks on wood*).
Hope all this makes sense and helps.
-CR
Old 12-09-2006, 10:28 PM   #6
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
as long as you install the gauge in the way the manual states, then yes it's accurate. The AP can't read over 18.3 psi.
Old 12-10-2006, 09:29 AM   #7
Fav Mod: Do Luck CF
Considered a PSi3 dash monitor? It displays ECU information - how much more accurate could you want? I considered getting one of these before I went with my DEFI setup, but I'm glad I got the DEFIs. I feel they are accurate, they respond extremely fast, and have a lot of nice features like peak/warn and record. I think my boost gauge reads about 1psi too high (I hope it does because my stage 2 ecutek car is reading 22psi sometimes) but I can adjust for that - it's leaps and bounds better than the stock gauge.
Old 12-10-2006, 04:24 PM   #8
Car: OBP STi
thanks a lot guys. I was gonna go with the psi3, but I became so attached to how well the Defis match. I wish there was more info on how people with defis can be installed to give the most accurate readings.
Old 12-10-2006, 04:55 PM   #9
Fav Mod: Do Luck CF
Don't see how I could have installed mine any differently, and I don't know for sure that they're inaccurate, but most stage 2 tunes don't reach my peak boost levels. I love my gauges, don't get me wrong, but I would like to know for sure how close it is. I may be getting a retune here soon since I've done a few things to the car since my last one in January. Anyhow, good luck with whatever you decide to go with.
Old 12-10-2006, 08:32 PM   #10
Trader Rating: (23)
to keep the gauges most accurate, the hose length that connects the source and the sensor must be kept to a minimum.
Old 06-21-2008, 09:33 PM   #11
Car: Rally Blue 06 WRX TR
Fav Mod: Driver/FlatFtShift& LaunchControl
Default Re: considering defi boost vs. eboost2
Even though this is a super old thread, hears one for the searchers. Eboost2 Baby!! Ive even heard Al from Dyno Flash say its the best one!
Valetudospang is offline   Reply With Quote
