Old 11-01-2006, 09:27 AM   #31
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
IWSTI Addict since: Jun 2004
2007 Postwhore King
Originally Posted by La Mer
i think it's too early too tell anything from this.
don't forget: dyno vs dyno never works.
Agreed. My points have been regarding the gains though - pretty spectacular delta values for just a reflash...
Old 11-01-2006, 09:31 AM   #32
NIИja
IWSTI Addict since: Jan 2006
absolutely!
i can't remember seeing any tuned, reflash-only dyno plots for any 04-06 sti's. that's one reason, im not "blown away" like some.
also, this is only one car. we all know how each car varies.
the gears, on the otherhand, are going to make quite a difference in a straight line.
Old 11-01-2006, 09:55 AM   #33
Fav Mod: Brum Brum
2007 Postwhore King
absolutely!
Peleg has an 04 STi protuned stage 1. There's a thread about it...
Old 11-01-2006, 02:10 PM   #34
Car: 05 Subaru STi
IWSTI Addict since: Apr 2006
Originally Posted by Ray_Sti
Wow.. i'm boosting at 20.5 on stock turrbooo..
I can peak 22 in the right conditions!
340AWHP on stock turbo!
I love Subarus!
ScoobyInc is offline   Reply With Quote
Old 11-02-2006, 09:27 AM   #35
Car: '07 STI Limited
IWSTI Addict since: Oct 2006
The Stock torque curve shown in Doug's graph is exactly what I am experiencing. There is a big flat spot in the torque curve between 3k and 3.5k RPM. It lags to about 3.5k or 4k RPM, then takes off like a rocket. Looks like even with the tune there is a small flat spot at 3k RPM (also much shorter).
I need upgrade my ECU somehow and not void my warranty.
haasSTI is offline   Reply With Quote
Old 11-02-2006, 09:45 AM   #36
Fav Mod: Brum Brum
2007 Postwhore King
AccessPORT (when it comes out, I guess) reflash, and hope your dealer doesn't find it
I'm surprised EcuTek was that quick to get the 07s figured out. It's the one time I'll give EcuTek props
Old 11-02-2006, 09:47 AM   #37
NIИja
The new Cobb AP2 will save your ORIGINAL Factory stock map for later use when you unmarry. When you unmarry, your Factory map is placed back in the ECU. Unlike Cobb AP1 where it wipes out your ORIGINAL Factory map, then flashes a generic "Factory stock" map when you unmarry.
This feature is the only real benefit that I see in the new AP2. Although it's too late for me, and most others. AP1 should have had some sort of disclosure explaining it does not save your Factory map. Oh well.
Old 11-02-2006, 09:52 AM   #38
Fav Mod: Brum Brum
2007 Postwhore King
Haha, I knew that before I reflashed, I was just told it would be hard to find the small difference between YOUR map and the generic one, so I jumped in
That's cool though.
Old 11-02-2006, 02:40 PM   #39
Car: 07 WRX STi Limited
Fav Mod: Trunk Monkey
IWSTI Addict since: Sep 2006
Got the same thing here... Interesting thing is that if you go out and do some spirited driving, it seems like it switches maps to one without that flat spot.
JiveMasterT is offline   Reply With Quote
Old 11-02-2006, 02:46 PM   #40
Car: silver 05 sti
Fav Mod: My SIRIUS radio...listening to Howard 100!!!!
IWSTI Addict since: Nov 2005
Send a message via AIM to raginbull74
wow...those are great # on the stocker....torque monster...I cant wait to see the #'s with an 07 with major mods!
raginbull74 is offline   Reply With Quote
Old 11-03-2006, 06:15 PM   #41
Originally Posted by HarryD
Along with everybody else, I am very impressed with the "Tuned but otherwise totally stock" dyno results on the '07 which ERADICATES the flat spot glitches in the factory tune.
I do have a question, though. Can someone explain the reason that the HP and Torque fall to less than the factory values at around 5300 RPM? Don't get me wrong, I LOVE seeing the FAT torque curve. Could this be where the stock injectors and fuel pump cannot keep up?
It's a result of shifting the torque curve... it happens.
edit... why did my post appear above Harry's?
Old 11-04-2006, 03:51 AM   #42
IWSTI Addict since: Aug 2004
HarryD is offline   Reply With Quote
