Old 10-24-2006, 09:54 AM   #1
Default APS downpipe cause boost creep.
I am currently sitting on Top Speed waiting on my car to start acting properly. It has some bad boost creep. Doug took off the actuator to ensure it was the exhaust and not the wastegate. Sure enough, more creep.
He said that he has removed the divider in the APS exhaust in the past and it has solved the creep problem. He took the downpipe to a machine shop real quick to get that divider out.
Ill post if that fixed the problem.
siusti is offline   Reply With Quote
Old 10-24-2006, 10:04 AM   #2
Fav Mod: Pro-Tune
Trader Rating: (16)
I just ordered my UR uppipe with a Tial 38mm WG to solve my creep problem. DP vains, porting wastegates, manual boost controllers, blah, blah, blah. I know after going around the world, asking 3 of the 5 top tuners in the country and countless other vendors and the manufacturer of my turbo, an EWG is the only sure thing that will cure the dreaded 20G creep problem.
CB
Old 10-24-2006, 03:13 PM   #3
Do all 20G's boost creep? Do you think you still would've had boost creep with an FP Green? I plan on doing one or the other...
docwyte is offline   Reply With Quote
Old 10-24-2006, 03:15 PM   #4
If the APS downpipe causes creep where others don't, then I'd say the APS downpipe is the better downpipe.
Old 10-24-2006, 04:58 PM   #5
I'd actually say that APS isn't the better downpipe.
Old 10-24-2006, 05:30 PM   #6
I said "if..." not was. In essence creep is being caused by increased exhaust flow. If the APS creeps where the others don't, it would seem it is less of a restriction than the others. Do you have a different angle?
I suppose on the other hand, one could argue that it is blocking the wastegate flapper in such a way as to reduce the ability of the wastegate to flow. Thus forcing more exhaust through the turbine. I don't personally claim to know which is the case. Just talking out loud. Hope that doesn't offend anyone.
Old 10-24-2006, 05:43 PM   #7
I dont know if I have a different angle. The boost creep was actually found to be a bad turbo after exhausting all options. Doug has been working with FP today on the issue and FP is sending a prototype exhaust housing gaurenteed not to creep.
Old 10-24-2006, 05:53 PM   #8
That's cool. Hope it works out for you and I'm glad the source of the problem is getting fixed.
