Old 10-19-2006, 09:55 AM   #16
Fav Mod: co-pilot
IWSTI Addict since: Jan 2006
try a hard reset of the ECU and reflash the RT map, i've had this happen to me twice now in the year i've been running my COBB AP. 8psi is the wastegate spring pressure, so basically it's like you aren't running any boost control and the wastegate is controlling the boost pressure. i bet the spool up is a bit slower to huh?
try that before you get pissed pulling the top mount off looking for holes or leaks, most of the time if you have a boost leak you can hear it hiss at the boost pressure it takes to push it open.
awd4life is offline   Reply With Quote
Old 10-19-2006, 06:00 PM   #17
IWSTI Addict since: Apr 2005
Same thing happened to my friends wrx last week. It was the vacuum line to the waste gate actuator, the line split apart. I would def check that out
JAB06 is offline   Reply With Quote
Old 10-20-2006, 06:18 AM   #18
Car: 05 Sti
I checked that line out last night and didn't find anyhting. My pressure is back up to 16.5 today. I'm looking forward to getting some new fuel in the system since I have a feeling that is the cause.
Thanks again for all the replys!
LateBraking is offline   Reply With Quote
Old 10-21-2006, 11:37 PM   #19
Car: Silver 04 STi
Fav Mod: 20g turbo
IWSTI Addict since: Mar 2006
I'm having the same problem I thought it was the line from the
t to the wg accuator. I put a new line on and a new pill in the line. No change. Theren't suppose to be two restrictor pills in the line from the turbo to the accuator? I checked the hoses they look good to me.
HNIC is offline   Reply With Quote
Old 10-22-2006, 12:02 PM   #20
Car: 06 Subaru STI
Fav Mod: DomTune
try yelling at your car
ArizonaSTI is offline   Reply With Quote
Old 10-23-2006, 06:18 AM   #21
Car: 05 Sti
I'm noticing this 8psi limit problem is intermittent. I'm ruling out bad fuel since I've been through 3 tanks now from different locations and still have this problem.
This issue happened to me 2x this weekend. I found that shutting off the car and restarting it can restore my boost. Does that give anyone an idea? I would think any vacuum leak would not be fixed by this. Bad ECU perhaps? Oh, it happens with both Stage1 and stock flashes.
Old 10-23-2006, 06:26 AM   #22
Car: Slow 05 STi
Fav Mod: Loping Idle
IWSTI Addict since: Mar 2005
Trader Rating: (12)
Boost gets cut if your IAM drop below a certain value which could explain your above statement. Keep good gas from shell, cheveron, 76, and etc. and see if that corrects the issue.
Old 10-23-2006, 08:51 AM   #23
Car: Silver 04 STi
Fav Mod: 20g turbo
I don't think I've ever seen full boost since I owned the car. I thought it was the boost gauge but I did some data loggin for the first time with ecuedit. It's reading 7.98psi. Does it make a difference that I have a IHI VF22 turbo?
Old 10-23-2006, 11:50 AM   #24
Car: 05 Sti
So you have always had the VF22 on your STi? If you are only putting out 8psi, you are REALLY missing out on performance!
Old 10-23-2006, 12:38 PM   #25
Car: Silver 04 STi
Fav Mod: 20g turbo
Yeah I bought the car with it. Imagine how I felt when I found out that there is more. I still don't know that much about the VF 22, still searching. I just want to get full boost out of it right now.
Old 10-23-2006, 01:31 PM   #26
Car: 05 Sti
I good tuner should be able to help you get more boost.
Old 10-23-2006, 05:35 PM   #27
Car: 06 STi
Fav Mod: Your Girlfriend Ridin Shotgun
IWSTI Addict since: Jul 2006
Send a message via MSN to Inertia
Go fill up with 100 octane and I mean fill up all the way drive that whole tank for daily use if the problem persists its not fuel related.
Inertia is offline   Reply With Quote
Old 10-23-2006, 06:12 PM   #28
Car: Silver 04 STi
Fav Mod: 20g turbo
I'm in florida I only put 93 oct. Is there a way to test the boost controller on the car?
Old 10-24-2006, 06:12 AM   #29
Car: 05 Sti
That sounds like a good idea. Now I have to find a place that sells that around here. Right now my car is running fine, so perhaps I'm out of the woods.
Old 10-24-2006, 09:30 AM   #30
Car: 01 Subaru WRX STi Sp
IWSTI Addict since: Aug 2005
Originally Posted by LateBraking
Has anyone ever run into the situation where you are only hitting 8psi in every gear? It just started to happen today when I filled up with a new tank of 93 oct? Could this be bad fuel?? I'm running Cobb Stage 1, 93 v1.10. I may try to unmarry the accessport and see is this is still an issue. Thanks! L
We have written a technical document explaining how the factory boost control system works, you can use this document to help diagnose your vehicle.
Take care,
Christian.
Christian. is offline   Reply With Quote
