| STI Driver Car: 06 Sti/White Fav Mod: APS FMIC/HarmanMotive tune Location: Orange County, Ca Posts: 214
IWSTI Addict since: Feb 2006 Trader Rating: (0) | Just wondering if it is slow like the Oil temp gauge. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Muller Chevrolet
Car: 08 Chevy 2500 Diesel Fav Mod: a new 09 STi Location: Milford, NJ Posts: 10,226
IWSTI Addict since: Oct 2004 Trader Rating: (11) | no the egt reads instantaneous...you give it throttle you see the needle move right away to a higher degree...when you let off it drops right away. oil temp moves slow because oil takes long to heat up and cool down lol. |
| | #3 | |
| Grassroots STI Racer Car: 05 STi Fav Mod: Not working in the Summers! Location: Highlands Ranch, CO Posts: 591
IWSTI Addict since: Apr 2005 Trader Rating: (3) | Quote:
Set your cruise on a flat road and the EGT gauge should hold steady. Start coasting (out of gear) and you should see readings drop right away. | |
| | #4 |
| Silver Member
Car: Aspen White 06 STi Fav Mod: Teh Mature Diffuser Will Return! Location: Queens NYC Posts: 2,778
IWSTI Addict since: Feb 2006 Trader Rating: (0) | +1... And the Oil Pressure and Fuel Pressure fly up like ur RPM. |
| | #5 |
| I Has a Turbo Timer
Car: 2005 Subaru WRX STi Fav Mod: Every single one! Location: NJ Posts: 10,119
IWSTI Addict since: Jun 2005 Trader Rating: (30) | Yup....my EGT's run up and down according to the revs.....where did you tap for it? That could be concern. |
| | #6 |
| S204 Racer Car: 2006 STI Fav Mod: Recaros Location: Mahan, OR Posts: 2,904
IWSTI Addict since: Sep 2005 Trader Rating: (1) | Sloooow. At idle, for example on startup, it takes 20-30 seconds to catch up. At higher RPM it lags significantly less, but still several seconds at best. Mine is mounted about an inch away from the exhaust port (left front). I've thought about changing mine out for something else, because with the lag, I just do not see that it is all that useful for anything other than eye candy. |
| | #7 |
IWSTI Addict since: Feb 2006 Trader Rating: (0) | I have not done this yet, but I am considering it. I just wanted to know if it was real time like my boost and oil pressure or slow like oil temp. Thanks for your input. This ad is not endorsed by this member. Please register or login to hide this ad. |
