Old 07-05-2006, 07:49 AM   #106
Car: 04 Subaru WRX STi, A
Send a message via AIM to Redleg9
A protune is either dyno-tuning or road-tuning your car by a cobb certified tuner. There are off the shelf maps available from reputable tuners, like PDX tuning.
You can Street tune it yourself using Street-Tuner software available from COBB.
Redleg9 is offline   Reply With Quote
Old 07-05-2006, 08:16 AM   #107
Flashed Stage 2 on Monday, drove it for the first time today(family got in the way of an immediate drive ) . Boost spIke!! I let off the gas when I saw 22psi! I need to hook up the AP for live boost on the way home and see what is going on...
Mods: AVO TBE, GPMoto equal length headers. The gauge was an Automoter electronic boost gauge.
Oh and I was one of the lucky to knock out the little plastic half moon in the valve cover.... 1 day job turned into a 3 day job! That is what you get when you hurry. Stupid irony...
RumblingREX is offline   Reply With Quote
Old 07-05-2006, 09:00 AM   #108
Live boost won't read that high so that won't help you. Try a LWG realtime map and that should solve your issue. Same thing happened to me.
RBMike is offline   Reply With Quote
Old 07-05-2006, 10:50 AM   #109
Car: 06 Subaru STi
Fav Mod: Deadbolt 20G
He's right ! The AP will only register up to 18.3 on boost.
Okeyd57 is offline   Reply With Quote
Old 07-05-2006, 11:46 AM   #110
Car: 05 Stizzle
Fav Mod: MagnaFlow Ti
Send a message via AIM to xtian67
how much boost am I supposed to be seeing on the Live boost reading?
I ordered a Defi boost gauge to compare.
xtian67 is offline   Reply With Quote
Old 07-05-2006, 10:16 PM   #111
Car: 06 Subaru WRX STI
another week or so and i'll be part of this group
cnguyen is offline   Reply With Quote
Old 07-08-2006, 01:26 PM   #112
Car: 05 OBP STi
Fav Mod: Protune FTW
Target boost is supposed to be 17.5 psi, 4th and 5th are good gears to test out whether or not your car is making the right amount of boost. To test mine I hooked up the AP and also monitored my factory boost gauge, start off at about 3k rpm's and go WOT, on the AP I see 17.2-17.8 maximum boost before it starts to taper down. The thing that really surprised me is that I see in the high 15 to low 16 psi range for second, and the full 17.5 or so psi in third (but only for a moment because the engine revs fast enough that the boost starts to taper). Make sure to test this out in a safe area as you will be accelerating WOT and have to take your eyes off the road momentarily to sneak peeks at the AP and/or your boost gauge.
Mongoose is offline   Reply With Quote
Old 07-08-2006, 05:55 PM   #113
Car: 05 Stizzle
^^ thanks mongoose
Old 07-09-2006, 04:11 AM   #114
Just installed the Cobb TBE catted and reflashed to Stage 2 yesterday, took me about 3 hours with a little help from my girlfriend, and I go a little worried when in all my excitement to drive it I had not noticed that I didn't bolt the BPV back onto the intercooler and needless to say the car didn't like that at all, but i brief stpo back at home to tighten the bolts on the BPV and I was on the road...It it awesome and the Cobb exhaust sounds mean with the 3in piping all the way down. Gotta love that boxer rumble...
sfclary is offline   Reply With Quote
Old 07-10-2006, 10:31 AM   #115
So far i have concluded that the k/n typhoon intake is bad for stg 2 cars??? today im prolly gonna do a few run's in 4th and 5th to see what im actually boosting at... 1 bar is 14.5 psi correct? so 1.5 is like 21 psi??? Sorry for the confusion... my mod list is turboxs rfl-ti tbe with race pipe, k/n typhoon, cobb stg 2... i just hope that i didn't hurt anything motorwise... and hopefully it'll work out, or i may just spend the extra $300 and go get it protuned...
NightriderWRX is offline   Reply With Quote
Old 07-10-2006, 03:37 PM   #116
Car: 2004 WRB STI/GOLD
Fav Mod: APS TMIC/CAI
Send a message via AIM to kb2spn
I recently installed the typhoon,completely shielded with air directed from the fog light.I had a helix catted tbe but switch the axle back to a bosal/spt.I think the response is great with a little back pressure in the exhaust.
kb2spn is offline   Reply With Quote
Old 07-20-2006, 03:10 PM   #117
Car: 06 STI
i am getting ready to have my stage 2 protuned by Doug from Topspeed and was wondering what kind of numbers to expect.
sti=#1 is offline   Reply With Quote
Old 07-20-2006, 04:45 PM   #118
Send a message via AIM to foofoodar Send a message via MSN to foofoodar Send a message via Yahoo to foofoodar
Originally Posted by DubyaSTi
Any one running a TurboXS stealthback with their Stage 2?
I'm debating whether or not to take the leap since, a) I have a K&N Typhoon which I would rather not remove, and B) I don't know if I want to deal with any boost creep issues.
Can any one with the Stage 2 and stealthback comment on if they've had any boost creep issues with that setup?
I have the TurboXS stealthback and a K&N Typhoon with my COBB Stage 2...its great.
foofoodar is offline   Reply With Quote
Old 07-20-2006, 06:42 PM   #119
Car: 06' AspWhite STi *S
Fav Mod: K&N typhoon, Helix TBE,
Just had my Helix DP installed along with my Defi Gauges and CF gauge pod on Monday. Flashed AP stage 2 v1.10 when i got home and took her for a spin, I can really tell a difference in 4th & 5th gear.. pull a lot harder.. also i have yet to experience a boost spike.. stays at about 19.5 then tapers down.
Warvetiraq is offline   Reply With Quote
Old 07-21-2006, 04:14 PM   #120
Car: '04 silver sti
Fav Mod: ap
Default need help with boost reading
ok here goes,to start with I have an 04 sti with a cobb catted D/P,and a stock cat back. Been running for two days with just the D/P seemed a little stronger and some what smoother. Today got an AP, flashed to stage 2 93 everthing went fine. Reads base map as what I wanted. Went for a ride and used the AP for boost reading it only seems to go to 10 psi max in all gears. I don't have an installed boost guage so this is the only reading I've ever gotten. Now I'm wondering if I've been missing even the stock boost for sometime. Also what should the AP read a idle in know it should be in vacum but just at idke it reads -9.5.I haven't had any cels or major problems with the car ever. I'm the original owner and bought it new. I've got 25,400 miles. Never really driven it that hard. Also noticed that if I try to switch to a stage 2 93 hwg real time map the AP still says that the current map is stage 2 93. Should it say HWG? The car still seems fast but not what I was expecting from going stage 2.I'm realy starting to think that something is wrong with the turbo or maybe the wastegate isn't closing and I'm bleeding out boost.I could use any advise or ideas. thanks, Chris
tugz is offline   Reply With Quote
