Old 03-18-2008, 11:56 AM   #721
Car: 05 WRB "STI"
Fav Mod: AP STG 2
IWSTI Addict since: Feb 2008
Default Re: AP Stage 2 Club
just got AP now! then im stage II now....yahhhhhooooo!
STInoel18 is offline   Reply With Quote
Old 03-18-2008, 11:58 AM   #722
Fav Mod: GT3076R
IWSTI Addict since: Mar 2008
i no longer have my stock air box :/ , what downsides will i be looking at until i get it pro tuned?
Sully is offline   Reply With Quote
Old 03-18-2008, 12:06 PM   #723
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
IWSTI Addict since: Jun 2007
You run the risk of running a little lean, bit I think you'll be OK with the SPT. The cobb map is designed to work with their short ram so there should be enough safety built in to run the SPT. If you aren't going to get protuned I'd recommend buying a stock air box. You won't lose any power and won't heat soak as bad in the summer.
Hitman83 is offline   Reply With Quote
Old 03-18-2008, 12:10 PM   #724
Fav Mod: GT3076R
thanks man, i should have it pro tuned withing 2 weeks of being done, sooner if i find a good place in jacksonville, nc. If not , while iam on leave in NJ.
Old 03-18-2008, 10:01 PM   #725
Car: 07 WRX STi
IWSTI Addict since: Oct 2006
OTS cobb maps run you so rich, you'll be fine without a protune for a few weeks.
Ooie is offline   Reply With Quote
Old 03-20-2008, 03:38 PM   #726
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
IWSTI Addict since: Sep 2007
Send a message via AIM to shan mann
just flashed to my stage 2 map..
overall very pleased with the power gain..
however i keep getting a CEL and blinking cruise light when i go WOT.. any reasons?
also my ap only reads to about 18.3 psi.. is that normal?
shan mann is offline   Reply With Quote
Old 03-20-2008, 03:45 PM   #727
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
IWSTI Addict since: Oct 2005
Send a message via AIM to 520
You are hitting boost creep.
the max the AP can read its 18.3 iirc. you are probably creeping above that.
Old 03-20-2008, 03:50 PM   #728
Car: 05 WRX STi
Fav Mod: cobb stage 2
IWSTI Addict since: Dec 2007
Time for an EWG or port the stock one!
dmc6996 is offline   Reply With Quote
Old 03-20-2008, 03:52 PM   #729
is there any other alternative?
Old 03-20-2008, 03:52 PM   #730
how do i reduce boost levels? and the AP manual says that it can estimate hp and torque?
Old 03-20-2008, 04:05 PM   #731
sorry but another question.. if i disconnect the battery.. will my map be gone?
Old 03-20-2008, 04:23 PM   #732
STI Master
Fav Mod: Whooshing sounds
IWSTI Addict since: Nov 2003
No, the map is stored in a ROM chip inside the AP.
Disconnecting the batt will only reset the ECU.
Old 03-20-2008, 05:35 PM   #733
^ thank you
is there anyway to find the estimated hp of my sti using the accessport and could the accessport reduce boost levels?
sorry im a noob to the AP
Old 03-20-2008, 06:13 PM   #734
STI Master
^ thank you
EAch map has its own parameters, which you can find on Cobb's website.
The stage 1 is 325 bhp and 340 lbs-ft
The stage 2 is 340 bhp and 385 lbs-ft.
These numbers are with 93 octane and a TBE.
I see that you're stage 2 already. I would get a walbro fuel pump and get customed tuned by a good known tuner. You can also add an APS CAI 65mm to the mix if you want some extra power and sound.
You can not reduce boost levels with the ap, that is done with a manuall boost controller which you DO NOT want to get.
You can change different maps though, so if you change to the anti theft mode, Im sure it boosts much lower and limits the rpm's for instance.
Once you get custom tuned (AKA: Pro-tuned), everything will be tailored to your car, from boost, fuel curves, ignition timing etc etc.
Last, since you have a V1, a cool mod would be to do the concealed display and hardwire it. PM me for info or if you have more questions, or post here if your question is stage 2 related.
Old 03-20-2008, 07:14 PM   #735
^thank you for the clarification!
i just figured that the cobb AP itself could find estimated hp of a vehicle.
i am running a injen intake which was protuned now i am stage 2 and i flashed to the Cobb Stage 2 93 v111 LC map. i am considering a walbro. then maybe a retune.
i have hardwired my Valentine one and have mounted it in the headliner and have the concealed display on my steering column. the v1 has saved my a$$ soo many times lol
thank for all the info!
