Old 02-10-2008, 09:21 AM   #691
Car: 05 Subaru WRX STi
Fav Mod: Bride Zeta III >=)
Default Re: AP Stage 2 Club
I am now in stage 2 myself
SD 05 STi is offline   Reply With Quote
Old 02-10-2008, 10:28 AM   #692
Car: 05 OBP STI
Fav Mod: STG 2
Just went stage 2 this weekend. cant feel much of a power difference but i still need to get protuned. and still need to find a way to get this CEL fixed.
EvO KiLLeR 2005 is offline   Reply With Quote
Old 02-10-2008, 11:50 AM   #693
STI Guru
Fav Mod: Whooshing sounds
What CEL are you getting?
Old 02-10-2008, 12:13 PM   #694
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
Send a message via AIM to shan mann
can you really feel the power difference with a cobb AP stage 2 map?
im running a full turbo back, injen cai, and up pipe.. stock psi, stock turbo.. would i really feel a big difference if i flash a map?
shan mann is offline   Reply With Quote
Old 02-10-2008, 12:21 PM   #695
i eat cones
Fav Mod: 18x8
Trader Rating: (16)
uh oh. you might not blow up your engine with map =/
dont run a downpipe w/o em lol.
and yes, you dont notice it too much in low gears, but highway and topend pulls are much, much harder.
also, with the mods you have, id definatly recommend a protune as well. the injen cai isnt like the stock diameter airflow.
Old 02-10-2008, 12:57 PM   #696
Car: 05 WRX STi
Fav Mod: cobb stage 2
stage two for the last 2 months...now time for the 100 oct. protune this tuesday!
dmc6996 is offline   Reply With Quote
Old 02-10-2008, 02:24 PM   #697
Car: 05 OBP STI
Fav Mod: STG 2
I DONT KNOW OFF THE TOP OF MY HEAD BUT ITS THE ONE FOR THE O2 SENSOR. BEEN LIKE THAT BEFORE I WENT STAGE 2. BUT I ALSO SCREWED UP AND DID TBE AND SHORT RAM INTAKE BEFORE I WENT STAGE 2 AND I HAD A CEL THEN BUT IT WASNT THE SAME ONE. IT WAS A WASTEGATE SILENOID CODE BEFORE. IM TOTALLY LOST I JUST NEED TO SEE IF IT WILL GO AWAY WITH A PROTUNE.
Old 02-10-2008, 07:15 PM   #698
Fav Mod: Custom built TBE FTW!!!
Send a message via AIM to CenCali07STI
wastegate solenoid code was probably due to overboosting since you did not have a stage 2 map loaded. Check yoru o2 sensor connections and make sure the wiring is in good shape. If thats good then it may be the sensor itself. The code might reference what 02 sensor is throwing the code I honestly dont know that. so check into it
CenCali07STI is offline   Reply With Quote
Old 02-10-2008, 07:37 PM   #699
Car: Black on Gold 08 STi
Fav Mod: ...
Went stage 2 last week on my 08... CAI, turbo back, access port custom tune. The car is running great.
Mediumturbo is offline   Reply With Quote
Old 02-10-2008, 07:43 PM   #700
i agree. 5th gear feels nice now
Old 02-11-2008, 05:34 PM   #701
STI Guru
The wastegate solenoid code is comming with the short ram intakes. I had that one night when it was 42 degrees and I opened her up.
Plug your AP and pull off the code from the ECU. It takes 2 minutes and will help you see what's going on, don't drive with codes like that, not a good thing.
Your mods are good, I would just get a CAI instead of the short ram, walbro fp and get protuned.
Old 02-17-2008, 05:45 PM   #702
Fav Mod: open invidia v2 catless
Went stg 2 yesterday. Defenatly worth the money. Well see what it helped at the track in a couple weeks. I do have one questoin. How do you use the code reader on the APv2? I was messing around with it after the install and even though I don't have a cel on the dash, the AP has a whole list of codes when it pulls them of the ecu.
blove is offline   Reply With Quote
Old 02-17-2008, 07:44 PM   #703
STI Guru
Plug the AP in, and on v.1 I think it's option 5 to pull the codes..........
Old 03-02-2008, 04:43 PM   #704
Car: 2007 STI Limited
Fav Mod: Stage 2
Send a message via AIM to coop1103
Stage 2 Officially today. Helix Catted Downpipe mated to a Perin Single Tube Catback. I am in love all over again with the car. The thing is a monster! Why would anyone spend $55k+ on a Corvette???? LOL
coop1103 is offline   Reply With Quote
Old 03-02-2008, 04:50 PM   #705
AP is in the mail!
soon to be an official stage 2!
quick question tho, when i flash my ecu to a stage 2 map, will this fix my overboost problem (boosting around 20 psi) and fuel cut problem?
