Old 04-23-2007, 06:37 PM   #436
I'm Jim Halpert
Fav Mod: Ricer Flyby
Default Re: AP Stage 2 Club
HEY! i just went stage 2!!!
Old 04-24-2007, 01:02 AM   #437
Car: 07 obp sti/07 cgm 2.
Fav Mod: Cobb Ap V.2
ok..i'm in
glamcem is offline   Reply With Quote
Old 04-24-2007, 03:46 PM   #438
Car: 05 WRX STI
Fav Mod: APS 3" / Assessport V1 Protune
I'm in. Went Stage II with a protune about two weeks ago. How much boost are you hitting by gear?? Gears 1, 2 and 3 are basically stock near 14.5 with 18.5 for gears 4, 5 and 6. Does this sound about right?? Protuned with Accessport V1
ou bobcat is offline   Reply With Quote
Old 04-26-2007, 12:54 AM   #439
going protuned stage II on may 9th from stage I. cant wait. 05 sti
listing of mods: so far just the spt intake/heatshield and ap v.2 (the spt intake/heatshield was an xmas gift from the gf, little did she know that was the tip of the iceberg)
on may 9: mods above + cobb catless tbe, cobb lightweight main pulley, protune.
i will probably post the dyno and some youtube vids (since ppl 2000+ miles away back home requested vids)
on a sidenote: does anyone have a video of someone, prefer 05 sti, running only a cobb tbe catless? interested in how it sounds and how loud it may be.. both under normal driving and wot.
esqdgg is offline   Reply With Quote
Old 04-28-2007, 06:22 PM   #440
Car: Silver 05 WRX STi
Send a message via Yahoo to import111
Went stage 2 ACN 91 octane map today. Car pulls harder than stage 1 for sure. I am only hitting 17 psi though. Stage 1 I was hitting 16.5psi. Not sure why I am not hitting closer to 18 psi like most other people running stage 2. On the bright side, 17psi is probably pretty safe.....and I am seeing 17psi at 3K rpm which is great.
import111 is offline   Reply With Quote
Old 04-29-2007, 10:35 AM   #441
Car: 06 sti
ohh man i just put my aps tbe on and i already look like this .... i am ganna wait a few days till im back to and to feel out the difference the i am installing my ap v2 to up my high back 2 lol. All the wooooooooot posts r right on the money
bhp808 is offline   Reply With Quote
Old 04-29-2007, 10:41 AM   #442
I'm Jim Halpert
i recommend putting the ap on as soon as you have the TBE on
Old 05-01-2007, 11:02 AM   #443
Car: 06 sti
i am probably 2day or 2moro, will that clear the check engine light and the annoying flashing criuse control light if i am catless? the cruise light always make me look down and think i still have my blinker on . Why is it that that light turns on as well?
Old 05-01-2007, 11:06 AM   #444
Car: Zohsex
Fav Mod: 295 rears
unsubscribed, i'm protuned now
kessler89 is offline   Reply With Quote
Old 05-02-2007, 08:30 AM   #445
Car: 07 STI Limited
I have an 07 STI Limited and just went Stage 2 in the last couple weeks. I have the Cobb AP v2 using their 91 octane 1.01 Stg2 map, and a Cobb catted downpipe. Everything else on the car is stock, including the cat-back. The turbo is spooling sooner now and the car feels happier in general because this tune is better than the stock one was for the most part. But I'm only seeing about 16 PSI boost, versus the 18.5 target listed in the map notes. I've seen it momentarily spike closer to 17 PSI for a millisecond in 5th gear, but most of the time it's rock solid at 16.
Anyone else with an 07 running this setup? Are you seeing sustained boost above 16 PSI? Does this sound relatively normal, or do you have any other suggestions? I've read about replacing the restrictor pills on the 07's for over/under-boosting but I'm wary about changing to an even smaller pill when the 07 already has a smaller one to start with. Sounds like an invitation to boost spiking. I've doubled-checked my DP and IC connections and that I'm running the correct map, and I've reset the ECU just to be sure.
Thanks.
Goofeth is offline   Reply With Quote
Old 05-02-2007, 08:59 AM   #446
Authorized Tuner
Fav Mod: My Laptop
Send a message via AIM to EFI Logics
Thanks.
Just as an FYI, you should not be running the stage II map with only a Downpipe, especially on the 07. Run the stage 1 map until you get the catback.
16-17psi sounds about right for a stage II, I've seen up to 19, but this is the 93 octane map.
- Chris
EFI Logics is offline   Reply With Quote
Old 05-02-2007, 09:08 AM   #447
I believe you are incorrect...the downpipe is the key element to stage 2. Catback is preferred but not required.
chumpsteak is offline   Reply With Quote
Old 05-02-2007, 11:38 AM   #448
+1
NEVER run stage 1 with an aftermarket down pipe
Old 05-03-2007, 04:11 PM   #449
I was told I can get stage 2 protuned with just a CObb catted DP. Was planning on taking the plunge soon to try get past these 07 issues
Can I just use the AP as my boost gauge as I did not get that option on my 07?
lidrew is offline   Reply With Quote
Old 05-09-2007, 11:29 PM   #450
tune day finally came.... i posted to the dyno page (repost below)... i have to get used to the bassy-ness of the new exhaust... it isnt a ton louder, just much more throaty. so far i am pretty happy.. gotta get used to it... may go for headers down the road to quiet the beast.... how are the #'s?
1. Car Year: 2005 sti
2. Stock HP (if you have it, no estimate please): unknown
3. Stock Torque (If you have it, no estimate please): unknown
4. Final HP: 285.1 @6750
5. Final Torque: 297.9 @ 3750
6. Intake mods: SPT intake w/ heatshield
7. Down Pipe (Make & model, catted/catless): Invidia bellmouth
8. Catback (Make model, catted/catless): Invidia G200
9. Engine Management (Ekutec, UTEC, AP stage 2 (octane) LWG or HWG, Protuner, etc.): Protuned stage 2
10. IC type (stock TMIC, FMIC, etc.): stock
11. Tuner (self or name of Tuner): fli
12. Dyno type (Mustang, Dynapack, etc): mustang
13. Location of Dyno (state): CA
14. Any other mods that might affect HP and Torque (Walbro 255, etc.): Cobb lightweight pulley, Prodrive 3 port boost control solenoid, Cobb double adjustable short through shifter
<!-- / message -->
