Old 03-14-2007, 12:53 PM   #361
Fav Mod: topspeed protuned
i just order my DP and cant wait to flash to stg2
white04sti is offline   Reply With Quote
Old 03-14-2007, 03:52 PM   #362
hey i got a question for you Stage 2 guys w/protune. Could you tell a "BIG" difference in gas mileage?? compared to when you only had TBE? please lmk going to stage2 w/protune
mods: PDE downpipe/ JIC titanium exhaust Spartan DE Type II / injen CAI.
jamestaSTi is offline   Reply With Quote
Old 03-16-2007, 12:49 AM   #363
bump anyone???!!?!
Old 03-16-2007, 10:45 AM   #364
Fav Mod: All of them
It wasnt a BIG difference, maybe a couple more miles to the gallon, but it will make a little difference if you stay off the go pedal.
Partysub is offline   Reply With Quote
Old 03-17-2007, 11:33 AM   #365
Car: 07 WRX STi
Edited because I was wrong about my AP. I had mechanical issues.
Ooie is offline   Reply With Quote
Old 03-17-2007, 11:34 AM   #366
Send a message via AIM to blaze0303
just ordered my helix dp off of gruppe-s, from my understanding this will bolt up with my stock exhaust no problem right? is there anything else i need to know, or is it really that simple?
blaze0303 is offline   Reply With Quote
Old 03-17-2007, 11:42 AM   #367
Fav Mod: CP35r 440whp
Originally Posted by Ooie
07 STi
stage 2 AP.
Going back to stock. My car runs WORSE now than it did stock. With the exception of the hesitation beging gone. I cant go WOT without sputtering and popping, the AP only reads boost up to 18.4psi, but the notes say that its tuned to go up to 19psi. I have no idea, the only thing people can tell me is that I need to be custom tuned.... So thats another $500 and still no 100% guarentee that boost issues will be solved. Anyone want my parts they all have about 150 miles on them.
confused. the sputtering and popping needs to be explained more. What's your boost issues?
Old 03-17-2007, 11:45 AM   #368
Fav Mod: Agile protune
Originally Posted by blaze0303
just ordered my helix dp off of gruppe-s, from my understanding this will bolt up with my stock exhaust no problem right? is there only thing else i need to know, or is it really that simple?
not really. call gruppe-s. they will explain it to you. i don't have the understanding to do so.
005sti is offline   Reply With Quote
Old 03-17-2007, 11:54 AM   #369
It is pretty simple. You'll need some PB Blaster to spray on the rusty bolts holding the old DP to the turbo & a couple of wrenches.
Look in the "how too" treads in this forum for instructions. I would recomend you take off the turbo heat sheild & spray all the bolt & let it sit for a few hour before you try to loosen them (I did it the night before). Don't use the stock donut gasket at the rear end of the DP, use the gasket that comes with the Helix.
RBMike is offline   Reply With Quote
Old 03-17-2007, 11:55 AM   #370
Car: 07 WRX STi
My boost issues, I guess is too much boost. It doesnt matter what gear I'm in. I cant go WOT. out of the exhaust, without cutoff I get sputtering and popping like back or afterfire noises and then a lack of acceleration, but no a fuel cut. the AP guage (because I have a cheap-o VDO guage) is what I'm going by because it is MUCH more accurate *i think* My car quickly gains full boost around 18.4psi or more then I get the sputtering and popping sounds, so I let off the gas and the car is normal again.
Old 03-17-2007, 12:26 PM   #371
do you have the LWG and HWG maps? I would switch to the map that lowers your boost level and try it then.
Old 03-17-2007, 12:46 PM   #372
Car: 07 WRX STi
I didnt see a LWG or HWG on the map selection on the AP
Old 03-17-2007, 12:51 PM   #373
www.cobbtuning.com
http://www.cobbforums.com/forums/showthread.php?t=32844
edit: damn. you have an 07, ill do more searching.
download it for the low boost. sounds like you're overboosting and then running lean, causing the popping condition.
Old 03-17-2007, 01:58 PM   #374
Car: 07 WRX STi
www.cobbtuning.com
So you want me to download a 2006 map for an 07? I agree that I need to do something. thanks for looking, I did find some good info in those links. I just dont have the LWG on my maps..... unless its a realtime map?
Old 03-17-2007, 02:04 PM   #375
Car: 06 WRB GOLD STI
Fav Mod: NRA Sticker
I dont think that you should download a 2006 map for your 07(too many things are different: turbo, gearing etc) I think that you should wait until monday and then give COBB a call. They will definately help you.
