Old 09-28-2006, 12:14 PM   #226
Car: 06 WRX STI
Fav Mod: Snow Meth Injection
IWSTI Addict since: Mar 2006
Originally Posted by FlyinbySTi
lol, that funny, cause I was talking to chris after he had tuned your car and he was telling me about it. I was thinking about running meth, but too, but my car is a daily driver and I do 30K or so a year don't know if it would like all that meth everyday.
The meth controller is set to come on at a certain PSI. No it's not like you are running it constantly. Also, you can always unplug it, and switch to the pump gas real time map. Then when you want the extra "oomph", you plug it in and switch to the meth map. It's pretty simple. Just make sure they mount the pump control unit in a place you can easily access.
BicketyBam is offline   Reply With Quote
Old 09-28-2006, 01:08 PM   #227
Car: 2004 wrx
IWSTI Addict since: Sep 2006
what about stg 2.5?? lol
i want in!!
marcymarc is offline   Reply With Quote
Old 09-28-2006, 01:22 PM   #228
Fav Mod: Stereo
IWSTI Addict since: Nov 2005
Originally Posted by Mayhem13
haha nice man how do u like it?
so far so good, love the extra pull. Only problem is that I have a bit of an exhaust leak. I am using a Helix DP with a stock catback. I left the donut gasket in (flat side to the DP) any way to fix this? Could I use some of that "Liquid Gaske" stuff?
Otter is offline   Reply With Quote
Old 09-28-2006, 06:42 PM   #229
Car: 05' STi
Fav Mod: JDM Fogs
IWSTI Addict since: Dec 2005
That's a good point. I wasn't really thinking of that. I may look into it.
Old 09-28-2006, 07:03 PM   #230
Car: 06 White Sti
IWSTI Addict since: Aug 2006
Send a message via AIM to toph3642
Default stage 2??
Im currently running an 06 sti with ap n catback n i was wondering if i can still run stage 2 with a greddy type rs bov...?
toph3642 is offline   Reply With Quote
Old 09-28-2006, 07:40 PM   #231
Fav Mod: Stereo
nope, you need a downpipe
Old 09-30-2006, 04:56 PM   #232
Car: 2006 WW EVO IX
IWSTI Addict since: Jan 2005
Send a message via AIM to ammarX786
I just went to stage 2 today, I LOVE IT!!!!!! Now I wanna goto stage 3, man I think I got the bug bad
ammarX786 is offline   Reply With Quote
Old 09-30-2006, 07:18 PM   #233
Car: 04 WRB STi
Fav Mod: Protune
IWSTI Addict since: Jan 2006
My wife RULES! Cobb AP for my B-day to go with the Cobb Catted DP I'd bought off the board but not yet installed. Stage II tomorrow!!!
ender18d is offline   Reply With Quote
Old 10-01-2006, 12:03 PM   #234
Car: 04 WRB STi
Fav Mod: Protune
The right tools, PB Blast the night before, and an extra set of hands FTW!
Stage II is unbelievable! The biggest improvement is in how fast the Turbo comes on.... but its stronger up top too. Much more fun to drive!
I logged almost perfect target boost... one early test run I briefly hit 18psi in 4th gear, but it quickly came back down... after that its been 17.5 all the way.
Old 10-01-2006, 02:04 PM   #235
IWSTI Addict since: Mar 2005
Finally at stage 2. Very easy to do and it is unreal just how fast the turbo comes on to boost now. You don't really feel the difference down low as much as you do up top. I'm only hitting target boost in 4th-6th gear though. I'm hitting just a tad over 1 bar in third.
Litfuse is offline   Reply With Quote
Old 10-02-2006, 07:38 PM   #236
Car: 06 WRB STI
Fav Mod: STG2+/Swaybars/RCE blacks coming soon
IWSTI Addict since: Jul 2006
How hard is to do cobb stg2 by yourself. I mean, if you already have the the AP and TBE purchased and sitting in the garage and ready to be put on the car. Can it be done by someone fairly inclined into mechanics and at home or do you need a local shop to at least install the tbe?
Thanks again.
karr1008 is offline   Reply With Quote
Old 10-02-2006, 07:48 PM   #237
Car: 04 WRB STi
Fav Mod: Protune
Thanks again.
I'm no mechanic, but I can follow directions. I managed the install with a friend (also not a mechanic)... You can totally do it yourself, but take your time, lots of PB Blast on the bolts, let it cool completely, and find a friend who can hold a wrench... (especially if you plan to take of the I/C like I did, an extra person helps put it back together!)
Still LOVING stage II! Smoooooth!
Old 10-02-2006, 09:02 PM   #238
Car: 06 WRB STI
So, no welding required on the TBE? Cool! Thanks for the reply.
Old 10-02-2006, 09:09 PM   #239
Fav Mod: Stereo
nope, just some bolt turning, and cutting of the heatshield. I would definately say have a friend to help, especially for when you are mating the new DP to the turbo. You will need one person under the car for support and lift and one above to line up the studs.
good luck, you'll love it!
Old 10-03-2006, 06:06 AM   #240
Car: 05' STi
Fav Mod: JDM Fogs
I didn't bother to put the heatshield back on.
I did mine without removing the topmount. It's really not that bad, I got the lower bolt from underneath everything else came off really easy.
The only problem I have had with Stage2 so far was some overboost the other night, it spiked up to 21psi and hit boost cut, tossed a CEL and everything. Cleared it and were back on track. Goes right to 17.5-18 and holds steady.
