| Spec C Club Car: Slow 05 STi Fav Mod: Loping Idle Location: Chewy's Garage Posts: 1,876
IWSTI Addict since: Mar 2005 Trader Rating: (12) | I am planning on getting protuned in June, and was looking into a couple of mods for a better tune. I am planning on buying an APS inlet pipe, NGK plugs, Walboro fuel pump, and some Helix 860cc injectors. I was looking at a post in nasioc about someone who just got protuned at Agile and the injectors seemed to help out a lot. He made 340whp and 380tq on pump and 350whp and 403tq on c16. My question is how much and is it necessary to buy some higher flowing injectors for a stock turbo tune? I am planning on getting a 20G in the future so I suppose I will be getting injectors eventually anways. Anyone have opinions on this? Thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| S204 Racer Car: 05|WRB|STi Fav Mod: Cobb Stage 2 Location: H-Town, NJ Posts: 3,796
IWSTI Addict since: Aug 2005 Trader Rating: (3) | The original fuel management IMO, is good enough for a tune on the stock snail. Plugs + the APS inlet is a good idea though. Um... I dont mean to hijack your thread but if you dont mind could you send me some pics of your rf-ti, because Im ordering the full tbe and Im just curious how it looks installed. |
| | #4 |
| Silver Member
Car: 05 & 09 WRB STI Location: Manchester, Maryland Posts: 2,238
IWSTI Addict since: Aug 2005 Trader Rating: (4) | having been down this road and friends of Agile/Hill, I can tell you that the stock fuel system is more than adequate for the VF-39 tuning. The only reason I could see to increase would be if you are seeing 90%+ duty cycles on your injectors.... |
| | #5 |
| Spec C Club
Car: 05' STI PSM Fav Mod: Leather Interior w/ Rear Pass thru Location: NYC Posts: 1,050
IWSTI Addict since: Nov 2003 Trader Rating: (4) | i am interested in this too... i know ppl with injectors have been putting down over 300 whp... not just 290whp at stg2 ps i have the rfl ti in the mail and it looks beautifulllllllllllll and sounds like a beast! |
| | #6 |
| Platinum Member Car: 2008 Forester Sports Fav Mod: "Proper" Break-in Location: LERSOC.com Posts: 3,951
IWSTI Addict since: Oct 2004 Trader Rating: (4) | stockers are fine. if you go bigger, i'd suggest what Cobb (and others) suggested at an EFI 101 tunning session in ohio this past feburary: DeastchWerks STi injectors (sp?) Modded, flow tested and marked for proper PnP installation. Hard to beat that. And, they run like 100-150 less than the pe850's. just a thought. Good luck, Brett |
| | #8 |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,715
IWSTI Addict since: Jun 2004 Trader Rating: (6) | The stock injectors work just fine for a high power VF39. No need for injectors. They won't get you anymore power. Yes, I have upgraded injectors on my Stage 2 setup ... and I am here to tell you they aren't needed on a VF39 setup (I installed them because I'm preparing for a turbo upgrade and I have the ability, knowledge, experience, and equipment to tune my own car). Granted, the IDCs are high with stock injectors on a high power VF39 setup. However, I have yet to see a single VF39 setup fail due to maxing out the stock injectors. They work. Many many tuners have tuned hundreds of STIs at Stage 2 with the stock injectors. You don't need bigger injectors for a stage 2 setup. Will they give you the warm and fuzzys due to reducing the IDCs dramatically? Yes. But, that is all you will get - warm and fuzzys. Period. t |
| | #9 | |
| Silver Member
IWSTI Addict since: Aug 2005 Trader Rating: (4) | Quote:
| | #10 | |
IWSTI Addict since: Oct 2004 Trader Rating: (4) | Quote:
yea well....maybe he's a lonely kinda guy. lol well put. | |
| | #11 | |
| Junior STI Driver Car: WRB 2005 STI 404whp! Fav Mod: COBB AccessPort Location: Slippery Rock, PA Posts: 114
IWSTI Addict since: Feb 2005 Trader Rating: (0) | Quote:
I was running 113% IDCs until I got my modified injectors installed. Moving from the PDX stage 2 to stage 3 map (only the addition of injectors and fuel pump) lowered my EGTs 60c!!! Depending on your final level of modification you may want to stay below 800cc. I found that once I went over 800cc my idle started to be noticeably rougher. Its not far from stock but its not as smooth as I would like it to be. The nismo 740cc injectors are most likely the best turnkey option for most people wanting to keep the stock turbo. I went the stock modified route and I have found it to be wonderful. | |
| | #12 | |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
Your EGTs didn't come down because of the injectors. t | |
| | #13 |
| Junior STI Driver | I just got tuned at Agile 3/24. My mods that matter are- 1) Cobb catless TBE 2) Cobb SF intake 3) Walbro fp 4) 1 step colder plugs 5) Prodrive boost solenoid 6) Protuned accesport by Hill 7) STOCK fuel injectors My #'s were 326.7hp@5547rpm & 330.7ft/lb@3873rpm. My AFR's were a steady 11:1 & IDC's 90%. I will be back at Agile on 4/15 to install my SMC kit running meth/h2o & Cobb crank pulley. I expect around 350hp & 375tq all on STOCK injectors. When Hill & I get finished with the meth my IDC's should be around 80%. *edit* This was on a 05 STi |
| | #14 |
| S204 Racer Car: 06 IX MR Location: Minneapolis, MN Posts: 3,666
IWSTI Addict since: Mar 2002 Trader Rating: (12) | Another option would be to go with an injection system. This route would lower your IDCs significantly by running a 100% meth tune or a 50/50 tune. Just thought I'd throw that out there since an injection kit should be less than injectors. |
| | #15 |
| Grassroots STI Racer | I want to start off by saying that I know nothing about tuning and what IDC's numbers mean, but if you say that it is possible to run IDC at 100%+ safely then I will skepticaly believe you base on my lack of knowledge on this; to me this means that they are running out of room in their efficiency range. So in my minds eye it makes sense to use a larger injector that easily runs the same capacity as the stock injectors at 100%. Does this make sense to anyone else, but me? I don't want to cause trouble, I am curious about this as well. I am debating doing larger injectors sometime soon, probably Nismo 720cc because I will be running a stock turbo untill much later in the year and don't want to go too large. Also, would running some kind of injection, whether it be water, alc or a mix lower your injector duty cycle? Wolfplayer - does your auto IC sprayer have any effect on your IDC's? This ad is not endorsed by this member. Please register or login to hide this ad. |
