| | #46 |
| The Next Petter Solberg | I bought mine from MZM Performance a while back. You might also want to check out the Nissan parts suppliers. The Nismo 740cc injectors are the same thing I believe. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #47 | |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,730
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
t | |
| | #48 | |
| Spec C Club Car: '99 M3/'03 WRX Avant Fav Mod: Modification is wrong! Location: SLC, UT Posts: 1,026
IWSTI Addict since: Sep 2004 Trader Rating: (6) | Quote:
| | #50 |
| Senior STI Driver | |
| | #52 | |
Oh well I have the 860cc injectors to play with. | |
| | #53 |
IWSTI Addict since: Sep 2004 Trader Rating: (6) | The 860's went in today and are coming out tomorrow. Whoa, the 860cc injectors are a little to large for a stock heads/cams/displacement. Keep in mind that I'm at 4200 feet, the 860s may idle ok at sea level with a raised idle. The pulse widths are on the ragged edge even with a raised idle. Can't wait to get the 720s in the car. We'll see if we can get rid of the faint RPM oscillation ![]() I may put the 860s back in when I go with CNC ported heads and C*** cams to see if I can get them to idle at that point Last edited by STirish; 02-18-2006 at 10:46 PM. |
| | #54 | |
1) I have noticed that my RPM oscillation can be noticed more during hot weather. Idle RPM was the same so I'm not 100% sure why the hotter weather made the oscillation more noticeable. One guess would be that the hotter inlet temps necessitate less fuel. I need to get logs of the idle RPM oscillation when it is not noticeable vs. when it is really noticeable. 2) Cams DECREASE the volumetric efficiency at idle .... thus, you need even less fuel at idle. This is why most people raise the idle when installing cams ... because the motor is just TOO inefficient due to the decreased Volumetric Efficiency (because of the increase in overlap). 3) Went on a 300 mile trip yesterday with the wife and kids. Car drove completely stock. t | |
| | #55 | |
| STI Driver Car: 01 Subaru WRX STi Sp Fav Mod: Coming Soon Posts: 263
IWSTI Addict since: Aug 2005 Trader Rating: (0) | Quote:
Christian. | |
| | #56 |
| The Next Petter Solberg | At idle, warm or cold (as cold as a cold start can get here in Floriday), it looks like I'm stuck at 1.54. Does this make sense? Were you expecting this or something else? |
| | #57 |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Holy reproduction Batman ![]() Mine is 1.54 also in both of the logs that I have reviewed (car fully warmed up such that the idle has dropped down to a warm idle). However, these logs were not taken when the RPM oscillation was that noticeable for me. I need to wait for a warmer day. It just chilled down into the 20's today ......... Brrrrrrrrrrr. And we are suppose to do motor mounts on my buddy's car tonight. t |
| | #58 |
| The Next Petter Solberg | A few more scatter plots showing that my fuel problem didn't go away, even though the trim plots "got better" with the restrictor in. Guess it really was just because it was harder for me to stay in closed loop in order to really see what was happening via the trims. This plot shows that the car still has a tendency to lean out around 2800. In fact, it shows that it generally wants to be 1 full AFR point leaner than the corresponding target in the primary fuel map table. Edit: For the following graphs, the Y axis is the difference between the measured AFR (via LM-1) and the corresponding target given in the primary fuel map (looked up via the load/RPM logged). So 0 (zero) means the AFR is exactly what the primary fuel tables asks for. So +1 would be one point leaner, and, -1 would mean 1 AFR point richer than requested. ![]() So, for fun, I modified the intake calibration and told the car the more air was getting in in the 2v-3v area. That produced this chart. Notice the definite improvement. ![]() Another interesting fact to note is the general tendency for the (eyeballed) linear regression to slowly work towards the rich side as RPM increases. Of course, the 2800 RPM lean bump is even more significant when you take that into accound. Question: Does this give a clue as to what is wrong? Does this happen on anyone else's STi? Was fudging the intake calibration the right/wrong/indifferent way to handle it? Related question: Is the general tendency towards rich as RPM increases related in any way to the scale/latencies I picked and should I change them to try and fix that? If so, which way (e.g. latencies up/scale down, or vice versa)? Or, should I just tweak the intake calibration to try and straighten it just like I did to get rid of that bump? Last edited by daemon; 02-19-2006 at 02:23 PM. |
| | #59 |
| The Next Petter Solberg | BTW, this is how I picked the 2v-3v area to play with on the intake calibration. I really need to tweak it a little better, but the quick expirement showed that it seemed to have the desired effect. Before... ![]() After... |
| | #60 |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | daemon, Nice. I think that you just need to keep track of the change you made in case you need to undo it later. However, I like the change you made. The car asked for something ... and you gave it what it needed. For now, this modification is working for you. Keep an eye on that area at WOT. I still need to grab some high quality logs for you to see if my car is doing the same. Drop me a PM when you get a chance to specifically tell me what you did while driving so that I can attempt to duplicate your logging method as closely as possible. t This ad is not endorsed by this member. Please register or login to hide this ad. |
