| | #16 |
| Grassroots STI Racer Car: 05 Subaru WRX STi Fav Mod: Cobb StreetTUNER Location: Elk Grove, CA USA Posts: 591
IWSTI Addict since: Jul 2004 Trader Rating: (0) | occilations during idle are almost expected but this is just weird. I'd knock out some fuelling in those RPM areas and see what happens. But first, if you plot the trim against load does that show any usefull info? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #17 |
| The Next Petter Solberg | The idle oscillations that we are seeing are a touch more than I'd expect. Definitely not huge though. My current theory on the idle is that maybe the latencies we are using aren't following exactly the right curve. That is, maybe the 14V value is spot on, but the 12V is a tad high or low. As the voltage in the system does its little fluctuations it would then move along the latency curve, and the next point would be a tad leaner or richer than the previous point causing the ECU to add or remove fuel. But then the voltage fluctuates back to where it was and then all of a sudden the AFR's are wrong again, but in the other direction. This may or may not be it, but sounds like a hypothesis worth checking out by slowly tinkering with the latency curve. I have plotted the trim against the load (and a bunch of other variations), and while there might be an extremely slight skewing towards the lean/high load area, it doesn't appear to explain the load vs RPM unless my load is dropping under constant acceleration above 2800 (and rising up to it), I'll have to look into that. One thought I had was that the turbo is going to be trying to get into the swing of things in that area. Which might be related to your question as well. These are low throttle plots, so the turbo is below zero, but still spinning of course. All things I plan to look at in closer detail. I am not going to have any time to work on the car again until probably Monday at the earliest, but I will definitely keep this thread posted if/when I figure out what is going on. Or maybe WolfPlayer will beat me too it. Last edited by daemon; 02-09-2006 at 02:11 PM. |
| | #18 |
| The Next Petter Solberg | FWIW, a little log showing the issue. Notice the trims climbing as I approach 2870 RPM, then they fall right back to where "they are supposed to be". Also notice the great skill I demonstrated in maintaining a constant throttle position of 18 the whole time. ![]() Code: Immed. Learned Voltage DynAdv Load RPM Timing Pulse MAFvolt Boost Throtle Speed W.Duty LM1-AFR -0.39 0.39 13.84 4.5 0.85 2342 42 3.84 2.42 -3.92 18 23 16.08 14.67 -0.39 0.39 13.84 4.5 0.85 2342 42 3.84 2.42 -3.92 18 23 16.08 14.38 0.39 0.39 13.76 4.5 0.85 2399 42.5 3.84 2.44 -4.06 18 23 16.08 14.38 0.39 0.39 13.76 4.5 0.85 2478 42.5 3.84 2.46 -4.06 18 24 16.47 14.38 0.39 0.39 13.76 4.5 0.85 2478 42.5 3.84 2.46 -4.06 18 24 16.47 14.38 1.96 0.39 13.68 4 0.84 2513 42.5 3.84 2.48 -4.06 18 24 16.47 14.55 1.96 0.39 13.68 4 0.84 2577 42.5 3.84 2.48 -4.06 18 24 16.86 14.55 1.96 0.39 13.68 4 0.84 2577 42.5 3.84 2.48 -4.06 18 24 16.86 14.55 2.75 0.39 13.76 3.5 0.84 2619 42.5 3.84 2.5 -4.21 18 25 16.86 14.55 4.31 0.39 13.76 3 0.83 2684 42.5 3.84 2.52 -4.21 18 25 17.25 14.52 4.31 0.39 13.76 3 0.83 2684 42.5 3.84 2.52 -4.21 18 25 17.25 14.52 6.67 0.39 13.68 3 0.83 2693 42.5 4.1 2.5 -4.35 18 27 17.65 14.52 6.67 0.39 13.68 3 0.83 2693 42.5 4.1 2.5 -4.35 18 27 17.65 14.52 7.45 0.39 13.76 2.5 0.82 2814 42.5 4.1 2.52 -4.35 18 27 18.04 14.64 9.02 0.39 13.76 2 0.81 2870 42.5 4.1 2.54 -4.35 18 29 18.04 14.64 9.02 0.39 13.76 2 0.81 2870 42.5 4.1 2.54 -4.35 18 29 18.04 14.64 7.45 0.39 13.76 2 0.8 2907 42.5 4.1 2.54 -4.35 18 29 18.43 14.64 5.1 0.39 13.76 2 0.79 2962 43 4.1 2.54 -4.5 18 29 18.82 14.29 5.1 0.39 13.76 2 0.79 2962 43 4.1 2.54 -4.5 18 29 18.82 14.29 1.96 0.39 13.68 1.5 0.77 3021 43 3.84 2.54 -4.5 18 30 18.82 14.29 -0.39 0.39 13.76 1.5 0.76 3014 43 3.58 2.52 -4.64 18 30 19.22 14.29 -0.39 0.39 13.76 1.5 0.76 3014 43 3.58 2.52 -4.64 18 30 19.22 14.29 -0.39 0.39 13.76 1 0.75 3117 43.5 3.58 2.54 -4.79 18 31 19.61 14.29 -1.18 0.39 13.76 0.5 0.74 3184 43.5 3.58 2.54 -4.93 18 31 19.61 14.29 -1.18 0.39 13.76 0.5 0.74 3184 43.5 3.58 2.54 -4.93 18 31 19.61 14.41 -1.96 0.39 13.76 0.5 0.73 3222 43.5 3.33 2.54 -5.08 18 33 20 14.41 -1.96 0.39 13.76 0.5 0.73 3222 43.5 3.33 2.54 -5.08 18 33 20 14.41 -1.18 0.39 13.68 0.5 0.72 3258 43.5 3.33 2.54 -5.37 18 33 20 14.41 -2.75 0.39 13.76 0 0.7 3310 44 3.33 2.52 -5.51 18 33 20 14.36 -2.75 0.39 13.76 0 0.7 3310 44 3.33 2.52 -5.51 18 33 20 14.36 -2.75 0.39 13.76 0 0.69 3276 44 3.07 2.52 -5.66 18 34 20 14.36 -1.96 0.39 13.76 0 0.68 3367 44.5 3.07 2.52 -5.8 18 34 20 14.36 -1.96 0.39 13.76 0 0.68 3367 44.5 3.07 2.52 -5.8 18 34 20 14.6 -1.96 0.39 13.84 0 0.67 3415 44.5 3.07 2.52 -5.95 18 35 20 14.6 -1.96 0.39 13.76 0 0.65 3436 44.5 3.07 2.5 -6.09 18 35 20 14.6 -1.96 0.39 13.76 0 0.65 3436 44.5 3.07 2.5 -6.09 18 35 20 14.6 Last edited by daemon; 02-09-2006 at 06:30 PM. |
| | #19 |
IWSTI Addict since: Jul 2004 Trader Rating: (0) | I wonder if doing a latencey test on the stock injectors would help. If they test just like the values in ST then we can look elsewhere. But if they come back with different numbers than what ST is using then something truley odd is happening. At least we could see if maybe we need to scale the test result numbers somehow before entering them into ST. Just thinking outloud here. |
| | #20 | |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,715
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
I am sending my stock injectors off to the same company that did the latency testing on my 720s. This will give a good comparison between the the 2 latencies ... and also let me know the flow of the stock injectors in relation to the flow of the Nismos. I'll be sending them off in about 2 weeks or so.Must ... get ... more ... data ... ![]() t | |
| | #21 | |
IWSTI Addict since: Jul 2004 Trader Rating: (0) | Quote:
![]() Actually I plan on ordering a set of these injectors with the next week. | |
| | #22 | |
... the only thing I wanted to mention is to make sure that you keep your goals in mind when ordering these injectors. These injectors are borderline for a BIG turbo upgrade. They'll be fine with a 20G. They'll be borderline for a Green. Anything bigger ... like 50+lb/min turbos then you should really go with a bigger injector like the PE850s or the Helix 860s ... or even the UR 900cc or 1000cc top feed injectors (comes with new rails). My goals are no higher than a 3" Green ... and, honestly, that is quite a ways away since I still have to install/tune my APS 70mm intake, get TGVs and port them, get a APS turbo inlet, etc. AND, if I do go with a Green ... then I want to update the intercooler with a Cobb Top Mount (just can't bring myself to do a front mount ... everybody does those and I think a Cobb top mount can handle a green). t | |
| | #23 | |
I kinda thought I could just raise the fuel pressure a tad if required later. Is this a bad idea? I'd raise it 1:1 not RRFPR. I haven't yet decided on the turbo. I was thinking about a Perrin GT30R .63 kit (I hate the idea of the foam underhood intake though) or a stock location Green or SR55 (like to see what happens between SOG and Peter with their little battle ).The stock location turbo has the advantage of being able to use the APS 70mm intake and new turbo inlet (hotttt). If I go rotated then I have to hack a CAI to work. If I go rotated then I'm 50/50 on going with the new APS DR525 FMIC in black (it's a little smaller and clears the foggies) or wait out the cobb TMIC. Lag/poor boost response is not my friend. This is my daily driver. | |
| | #24 | |
If the fuel pump can flow the necessary fuel at the higher pressures then sure. But, if not, then bad things will happen. A Dual Walbro setup should take care of that though ![]() t Last edited by WolfPlayer; 02-11-2006 at 05:44 PM. | |
| | #25 |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Well ... I played around with checking out the battery voltage at idle. Honestly, I am getting hardly any deviation in terms of battery voltage at idle ... at least nothing to me that would ever cause an RPM oscillation. BTW, it is just so hard to detect my RPM oscillation. Sometimes I wonder if I am just convincing myself there is one there when there isn't. t |
| | #26 | |
| | #27 | ||
| STI Driver Car: 01 Subaru WRX STi Sp Fav Mod: Coming Soon Posts: 263
IWSTI Addict since: Aug 2005 Trader Rating: (0) | Quote:
Here is the equation for the "Pressure Effect on Fuel Injector Flow" Qn = Qc _/(Pn/Pc) Qn = New flow rate Qc = Current flow rate Pc = Current pressure Pn = New pressure _/ = Square Root / = Divide Hope this helps. Take care, Christian. | ||
| | #28 | |||
| Senior STI Driver | Quote:
Also, it seems that the MZM latency values as well as the Witchhunter (Wolf posted) values seem quite a bit off. Prior to Daemons post I had been using a 4205 scalar and latency value of .78ms @ 12v and .60ms @ 14v for a month or so with nearly identical results. I cannot tell the difference between the two settings..... Quote:
I have been through this entire "cycle" with the PE850's already, with very similar results. The PE installation was almost identical (harness clips as well). Had the PE's for about 6 or 7 months. Installed them a week after I installed the Street tuner. The issues with tip-out were bothering me as well as the idle fluctuation. Spoke with Christian and Trey about adding some tip-out control in October. The tip-out issue did not appear to be something that I would be bothered with, but long term tailpipe / bumper soot thing started to get under my skin (yes I am probably being too anal...). Trey relayed that some type of tip-out control was under future consideration (Christian and Trey have both been very insightful and helpful by the way). So recently, was curious to see if the issues I was having could be cured by a different injector. This led me to install the 720/740's. Bottom line, it turns out they are really quite similar in all areas except duty cycle values. Quote:
Anyone with with extended "hands on" experience like we are discussing here, but with modded stockers? | |||
| | #29 | |
Also, the OEM regulator is boost referenced and provides a 1:1 gain (if your pump will support the pressure). | |
| | #30 | |||
This ad is not endorsed by this member. Please register or login to hide this ad. | |||
