Old 09-22-2005, 06:02 PM   #1
Car: 05 CGM STI
Fav Mod: GT-30
Default Location of Fuel Pressure Regulator?
Just got a boost controller...does anyone know where the fuel pressure regulator is located??? Thanks
949_STI is offline   Reply With Quote
Old 09-22-2005, 06:24 PM   #2
GT R US
up by the driver side front strut tower. you'll see the two very small black fuel dampers connecting rubber fuel hoses on a bracket. the fuel regulator is right there in a natural finish.
Old 09-22-2005, 07:08 PM   #3
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
nooooo. boost controllers on stock sti without proper tuning is BAD. you need to be able to control afr's before you can mess with boost. if your going about this in the correct manor then what bruce said should be fine.
Old 09-22-2005, 07:39 PM   #4
GT R US
i didn't notice why he needed to know where the regulator is.
Old 06-19-2008, 09:30 AM   #5
Car: Yellow 03 Evo 8
Default Re: Location of Fuel Pressure Regulator?
dont you need to know were it is to tap it off for a boost gauge?
Pedro Martinez is offline   Reply With Quote
Old 06-19-2008, 09:59 AM   #6
NEVER I MEAN NEVER TAP FPR LINE FOR ANYTHING.
You do NOT want any leaks in the FPR vacume line. Putting a tee in that line increases having a leak 100%.
Use the BPV line or the UFO thing at the front pasenger side of the intake.
TheMadScientist is offline   Reply With Quote
