Old 05-11-2005, 01:26 PM   #16
Car: Subaru
Fav Mod: N/A
rodent:
My understanding is this: The ECM makes decisions for the A/F based on input from the front O2 sensor and the rear O2 sensor. The front does most of the input with the rear doing the fine adjustments. The ECM based on what it sees from these two sensors (and other I/O) is constantly adjusting the A/F based on the stored map(s).
You might be able to get away with disconnecting the rear O2 sensor, but if you have a cat I would keep the rear sensor hooked up to keep from long term degradation of the catalyst element. It can scorch if too lean or explode if overly rich condensation is allowed.
ParkerSTi is offline   Reply With Quote
Old 05-11-2005, 01:59 PM   #17
Car: 95 GSX
I don't have a cat.
I talked to Cobb and they said it shoudn't hurt anything by having it out. They said I could short the two heating wires together but don't suggest it. I think I'll just get another o2 bung welded in and re-install it.
rodent is offline   Reply With Quote
Old 05-11-2005, 02:11 PM   #18
Car: Subaru
Fav Mod: N/A
rodent:
Hate to say it, but that might be your best option.
And for shorting the heater wires, I think that could cause problems since they are sourced from the ECM.
My TBE came with an extra bung just below the turbo for just this sort of application, but I have never used it.
Old 05-11-2005, 05:40 PM   #19
Car: '04 WRB
Fav Mod: A working ECU...
Yes, the first O2 is used for engine control, the rear is solely used for OBD II (emissions) monitoring...
Old 05-11-2005, 06:51 PM   #20
Car: '99 M3/'03 WRX Avant
Fav Mod: Modification is wrong!
I think the '05s only have one O2 sensor, you guys were really worrying me for a second
STirish is offline   Reply With Quote
Old 06-24-2008, 03:08 PM   #21
Car: Black 05 WRX STi
Default Re: Cobb Stage 2 and Rear o2
Thread back from the dead.
I just installed on my 05 STi a Greddy Evo 2 mid and cat pipe with an Invidia V2 DP.
The O2 Sensor won't fit in the supplied bung so I just plugged the hole and disconnected the sensor (the sensor bumps against the drive train). How do I get rid of the CEL for the o2 sensor? My Cobb AP resets it temporarily until I turn the car off. Then it reappears.
I searched this site for some kind of fix, but can't seem to find a definitive answer.
Can anyone help on this?
Thanks
RXAK is offline   Reply With Quote
