Old 02-09-2010, 07:46 AM   #1
Fav Mod: Crawford Gymkhana Exhaust
IWSTI Addict since: Aug 2004
Default Quick AP question
My Dad's bone stock 08 has check engine light, flashing cruise light, and stuck in S mode. I was wondering if I could use my AP that is married to my 08 and pull a code off his for research into what might be going on. Also if this is possible, would I be able to clear the code as well?
Thanks
vermilion is offline   Reply With Quote
Old 02-09-2010, 01:50 PM   #2
Car: White 08 WRX STi
My StuffSubaru Parts
IWSTI Addict since: Mar 2009
Default Re: Quick AP question
Yes, you can look the code up and even reset the ECU. The check engine light will cause the ECU cruise light to flash and the SI-Drive system to sit in S mode.
Travis
COBB Tuning
COBB Tuning is offline   Reply With Quote
Old 02-09-2010, 03:27 PM   #3
Thanks much.
Old 02-10-2010, 11:37 AM   #4
Hmm, threw two codes. P2440 and P1410. Its weird that these two would cause him to go into S mode only (safe/limp mode) with cruise flashing and check engine light.
His car is bone stock except for some Volk wheels. It seems from posts I'm reading that every car that has had these codes pop up was Stg1 or better.
Similar Threads
Quick question! STi413 GR-Tires & Wheels 8 09-24-2008 05:37 AM
Quick Question! n8ivesoulja 2.5 Liter/Litre Factory Motor 7 09-06-2008 06:46 PM
Quick question on reflash slade1274 ECU Tuning & Performance Electronics 11 09-03-2008 07:43 AM
Quick question about heat and the affects on boost... SD 05 STi 2.5 Liter/Litre Factory Motor 2 04-13-2008 10:16 AM
Quick dumb question about the Helix CEL Fix Crewchief General 1 06-13-2005 05:19 AM
Privacy Policy
