AF ratio - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
STI Products
Go Back   STI Forums > IWSTI Engine & Drivetrain > ECU Tuning & Performance Electronics > AF ratio
Old 01-07-09, 03:42 PM   #11
Advanced Mastery Level II
Feedback Score: 14 reviews
Car: 2005 & 2008 STI
Fav Mod: Scott Siegel Tuning!!!
JDM-STI is an unknown quantity at this point
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
Default Re: AF ratio
No, not accurate. It's for closed loop fueling. Basically non-WOT driving.
2008 STI Aspen White/Gold BBS~305whp/369wtq
Tuned by Scott Siegel
JDM-STI is offline   Reply With Quote
Old 01-07-09, 05:39 PM   #12
Feedback Score: 1 reviews
Fav Mod: Innovative Tuning
Inn-Tune is on a distinguished road
Not only does it not read richer than low 11's AFR, it reads that in many cases where you're leaner than that. For example, I've seen the stock sensor read that when I'm "really" at 12.0 AFR as per a wideband.
A good wideband controller with a wideband sensor that's in good working order and properly calibrated should always be used for accurate tuning and monitoring. The stock sensor is acceptable for a course idea of AFR while at idle and while cruising or decelerating.
Mike McGinnis
Innovative Tuning
(716) 873-7360
sales@InnovativeTuning.com
http://www.InnovativeTuning.com
Inn-Tune is offline   Reply With Quote
Old 01-07-09, 08:07 PM   #13
Car: '07 STi Limited #482
WRX4ME LE 482 is on a distinguished road
Originally Posted by Shamoo View Post
The stock oxygen sensor is not very accurate and is pretty much only good enough for closed loop operations. I believe that the lowest it will read is around 11.1 (atleast that's what mine does).
I'd look into an aftermarket wideband for accuracy.
Cmon now, that's not exciting. I love knowing my a/f could be anywhere from 10-14 when I'm at 19.5 psi. Sort of like russian roulette...
Stage 1 Enginuity tuned by me.
11/9/2007: 13.1 @ 103.9, 1.66 second 60 ft, 59 degrees, Hub City Dragway.
Check it out! http://www.dragtimes.com/Subaru-Impr...lip-13893.html
Looking for used/cheap divorced WG, 3" downpipe for my 07 STi! PM me if you're sellin!
Old 01-08-09, 01:05 AM   #14
Advanced Contributor Level 4
Feedback Score: 3 reviews
Car: 2005 STI (White)
Fierysun is an unknown quantity at this point
What's a good aftermarket oxygen sensor?
Fierysun is offline   Reply With Quote
Old 01-08-09, 03:16 AM   #15
Car: 04 AW STI
Fav Mod: Moore Performance Turbo Back Exhaust
FORCFED is an unknown quantity at this point
AEM - Gauge-Type Wideband UEGO Controller
This is the one i ordered and seems like most people are running this.
Gauge-Type Wideband UEGO ControllerFAQs...A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometersDoes not oscillate AFR reading like narrow band sensorsNo laptop required for monitoring!Bosch sensor includedAccurate to 0.1 AFRReads in AFR or Lambda via a switch in back of gauge housing24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratioIntegrated three-digit display reveals AFR or Lambda in real timeUser-programmable 0-5v analog output included for use with data loggers and virtually any engine management systemSerial data stream included for output of AFR (RS 232)
FORCFED is offline   Reply With Quote
Old 01-08-09, 04:29 AM   #16
Advanced Mastery Level III
Feedback Score: 4 reviews
Car: 09 OBP "The Hearse"
Fav Mod: Shiney stuff
ToeKutter is an unknown quantity at this point
On this note, how does one make sure that the WB system is properly calibrated and showing accurate numbers? Actually, the O2 sensor is probably the piece that is most likely to fail with time, so my questions is - how to you tell that your WB O2 sensor is reading accurately?
ToeKutter is offline   Reply With Quote
Old 01-08-09, 05:09 AM   #17
Car: 08 STi
SRH_STi is an unknown quantity at this point
To make things even more dfficult, the sensor should be placed far enough away from the turbo so the heat doesn't affect it in any way (not just the reading, but heat can also damage the unit). I believe they usually say at least 14 inches from the turbine discharge, although I often see them only inches away.
ALSO, the sensor should always be angled upward in the exhaust pipe to prevent moisture from collecting on and damaging the unit.
SRH_STi is offline   Reply With Quote
Old 01-08-09, 05:12 AM   #18
Contributor
Car: SWP 09 STI
Fav Mod: none
ahgil is an unknown quantity at this point
great so i guess i should get a wideband to make myself better by seeing more accurate no. thanks for the info guys
ahgil is offline   Reply With Quote
Old 01-08-09, 11:17 AM   #19
Car: 04 AW STI
If the o2 sensor needs to be 14 inches away from the turbo why does cobb put so close?
Old 01-08-09, 11:19 AM   #20
I though it was 6in or so. (That's what she said...). There's actually a nice LC-1 instruction manual available from their site, I believe that talks in great detail about this.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Privacy Policy
