| Platinum Member Car: SWP 07 sti Fav Mod: Tic holy shift kit, HKS Hi power exhaust, COBB Stage 2 Posts: 60
IWSTI Addict since: Jul 2008 Trader Rating: (0) | I flashed to stage 1 this afternoon. Since my car is stock I chose the first map offered on the AP, 91 octane. Install went smoothly, and I have since put about 30 miles on the car. After warm up, the engine idles smoothly & steadily at exactly 500rpms. There have been no CEL warnings. I did not have the car dyno'd before or after the install, so my basis is only by "feel", or as you guys call it ..the butt dyno. I did find a gas station (Aloha Petroleum) that has 92 octane that I believe does not contain ethanol, so I filled 'er up. If their gasoline at this station does contain ethanol, they have not posted stickers on the pumps informing the public of that fact. The car pulls smoothly & powerfully thru all six gears. I am impressed by that. But here is the problem (or maybe not). There is still a slight surge in 6th gear when holding steady on the throttle at highway speeds. In 3rd gear, I noticed a surge much more prounounced than before I performed the reflash. While holding the throttle steady at exactly 2250rpms I thought I was on a bucking bronco. Did I use the wrong map? What could possibly be causing this? If I gottta live with it then so be it. But it just doesn't seem right. Any suggestions? Thanks Guys!! This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| IWSTI Addict Car: 07 STI OBP Fav Mod: 57maximum t/a, Nur spec-R, invidia v2. EFI TUNE Location: Bushkill, PA Posts: 1,608
IWSTI Addict since: Feb 2008 Trader Rating: (3) | when i flashed stg1 i had no prob. but you gotta let hte car get used to it. it will be smoother after you drive it for a while. |
| | #3 |
| Professional STI Driver Car: Blue 07 WRX STI Fav Mod: Soap Location: Winston Salem, NC Posts: 435
IWSTI Addict since: Apr 2007 Trader Rating: (0) | When I reflash, I take it easy on the car for a while and then I go WOT very slowly. I don't know if it makes a difference, but I don't wail on it when the ECU is learning. I had no problems with Cobb Stage 1. Stage 2 has had a few hestitation spots at 3,000 rpm but they are intermittent. |
| | #4 |
IWSTI Addict since: Jul 2008 Trader Rating: (0) | I drove it the way I normally do after the reflash. I took it easy for a few miles and when she was warmed up I went thru the gears but no red lining. I put about 110 miles on since yesterday. I have been out driving all over the place hoping the ECU will get its degree. I was under the impression that a reflash with AP stage 1 would have cured the surging/bucking issue. Like I said earlier... its not something I can't live with but I sure was hoping it would go away for good. Maybe it needs more time. I don't know. If anything, I hope the AP has at least cured the lean running conditions innate to the '07's. |
| | #5 |
| Amateur STI Driver Car: 07 STi Fav Mod: Stage 1 Location: Gardiner NY Posts: 9
IWSTI Addict since: Sep 2007 Trader Rating: (0) | i am installing the ap right now on my 07.... i get the same bucking and i hope it goes away..... ill let you all know tomorrow when i get back from work This ad is not endorsed by this member. Please register or login to hide this ad. |
