Old 07-08-2008, 06:30 PM   #1
Car: 06 Subaru WRX STi
Fav Mod: seatbelt beep delete
Default Should i uninstall AP before removing battery? URGENT
Ok, so i just had the instrument cluster malfunction, and after doing a search on here i found i just have to remove both battery terminals for a few seconds and then reconnect them. Should i uninstall my AP before i do this?? Will it mess with the marriage of the AP and ECU?
06AspenWhiteSTi is offline   Reply With Quote
Old 07-08-2008, 06:32 PM   #2
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Default Re: Should i uninstall AP before removing battery? URGENT
You'll be fine. The only thing it will do is reflash whatever your realtime map is. If it is the same as your basemap, don't worry.
Old 07-08-2008, 06:33 PM   #3
Fav Mod: GT35R 450+WHP Pump No Meth
No it will be fine, it is flashed on your ecu and there until you physically replace it or unmarry the AP. I have had the battery out many of time with no problem.
Old 07-08-2008, 06:34 PM   #4
ahh, i see cool, thanks. When the cluster first malfuntioned, i got kinda scared. I was like "what the f*ck did i do now"
Old 07-08-2008, 10:27 PM   #5
and problem solved. i love this site.
