Old 07-07-2008, 03:10 PM   #1
Car: 05 STI
Fav Mod: Covering those ugly stock fog lights!
Send a message via Yahoo to aakrusen
Default IDC on Cobb stage 2?
What is the injector duty cycle for the 05 STi on stage 2? What would they be after a protune while mainting stage 2 mods (with the addition of a Walbro, ofcourse)? How do you know when to upgrade the injectors?
aakrusen is offline   Reply With Quote
Old 07-07-2008, 03:24 PM   #2
If in doubt, flat out
Trader Rating: (23)
Default Re: IDC on Cobb stage 2?
I had IDCs into the 100+% with my last protune.
From what I've read in several tuning books, the general consensus is anything above 80% can lead to inaccurate metering of fuel, overheating injectors, accelerated injector wear and failure.
Old 07-07-2008, 03:32 PM   #3
Non-Reformed Meth Addict
Car: '06 WRB
^^^This would be 100% correct. My IDCs were 102-104% on the stock injectors with a Walbro stage 2 with meth. Now I'm running an 18g at 26psi and with DW 740s my IDCs are 78-80%.
Old 07-07-2008, 03:45 PM   #4
i eat cones
Fav Mod: 18x8
Trader Rating: (21)
its gonna be high... 90+. i have a walbro pump, supposedly it can help by some %.
Old 07-07-2008, 07:06 PM   #5
Car: 05 STI
So, do I get injectors before my protune? I'd rather pay more now for injectors than later with a blow motor. What size are my injectors now? How big should I go for a protuned stg 2? Can I put the injectors in right before I drive to the tune?
Old 07-07-2008, 07:24 PM   #6
Trader Rating: (23)
the bigger injectors will need to be scaled before you drive your car to get tuned. a competent tuner will be able to get a limp map together for you to drive your car in on. there are many injector options out there, talk to your tuner about what he feels is best. Many people have had great success with deatschwerks injectors.
Old 07-08-2008, 07:22 AM   #7
Ask your tuner. What that person thinks should be more important than what this forum thinks based on who knows what.
You may be able to install the injectors if your tuner supply's you with a limp map.
parkergc8 is offline   Reply With Quote
