Old 06-24-2008, 03:28 PM   #1
Car: White 06 WRX STi
Fav Mod: Cobb Accessport v2
Default How safe are Accessport version 1
I am thinking about purchasing a used Accessport version 1. I have heard that they can brick your ecu if not install correctly. Has this happened to anyone? Also is there any way to know by reading the serial number or any other way to identify what year the accessport is for?
billys06sti is online now   Reply With Quote
Old 06-26-2008, 11:38 AM   #2
Car: REMO RED,2004,WRX
Send a message via AIM to ChrisNJ
Default Re: How safe are Accessport version 1
its fine to use but you got to rember thqat you puting more power in to your car so its harder on the tranny my 4th gear syncros are bad cuz im puting to much power so i am puting a new tranny in so its all good lol
ChrisNJ is offline   Reply With Quote
Old 06-26-2008, 11:54 AM   #3
Fav Mod: topspeed protuned
you also have to remember you have a wrx not a STI the sti trans is much more stout than the wrx tranny.
white04sti is offline   Reply With Quote
Old 06-26-2008, 12:05 PM   #4
Car: CGM 05 STi
Didn't they used to (or still do?) call the WRX tranny a "glass transmission" for that reason?
redeye is offline   Reply With Quote
Old 06-26-2008, 12:07 PM   #5
yea but i didnt want to say it like that some people will get there feelings hurt
Old 06-26-2008, 12:10 PM   #6
Car: CGM 05 STi
hehe, I guess I'm heartless.
Old 06-26-2008, 12:15 PM   #7
abracious
Fav Mod: Track time
APv1s are perfectly safe. There is absolutely nothing wrong with them, save that they are not as "cool" as v2s and have map size limitations.
The map size limitation is not a huge problem, as your tuner should be ale to create a safe tune within the limits.
People who damage their ECU on a v1 are simply not following the simple instructions. I used one for years and never had a single problem.
Old 06-26-2008, 02:33 PM   #8
Make sure you don't use the wrong power adapter. That would be an expensive repair for s product that is discontinued.
parkergc8 is offline   Reply With Quote
Old 06-26-2008, 02:46 PM   #9
Yeah I am just looking to buy a used accessport. I do not need launch control or anything. I just been reading the instructions for the version 1 and I see that you have to make sure that the plug stays in while you are reflashing the ecu and the battery has a good charge. Or you will mess up your ecu. How long does it actually take to reflash the ecu for the first time I heard between 30 and 45 minutes is this true.
Old 06-26-2008, 04:23 PM   #10
Car: 06 SRR WRX Wagon
Fav Mod: Bone Stock
People were losing their ECU's because their battery would die mid flash. Once this happens you have to send in your ECU for a new stock map and try again. Make sure you have a good battery and a good charge before flashing.
subarulz is offline   Reply With Quote
Old 06-26-2008, 08:05 PM   #11
Car: 06 Subaru WRX STI
Fav Mod: Headlight Adjustment
Send a message via ICQ to MasterColin Send a message via AIM to MasterColin
I've use a V1 and yeah it takes a good 25min to flash. I haven't bricked it and my cord is bad so I must wrap it around the AP to keep pressure on it so that it keeps going.. (Cobb said there are problems with the AP V1 cords and that because of that they would replace it if i sent it in (free))
MasterColin is online now   Reply With Quote
Old 07-13-2008, 08:50 AM   #12
Car: 07 Subaru WRX STi
Fav Mod: 2006 XTerra
Send a message via AIM to jedon
Will an APv1 work on an 07 STi?
jedon is offline   Reply With Quote
Old 07-14-2008, 09:08 AM   #13
The original AP's were discontinued before the 07 flash info was completed.
Short answer no, the New AccessPORT is the only one with 07 programming.
Old 07-14-2008, 09:54 AM   #14
Thank you for the info!
