Old 06-19-2008, 08:09 AM   #1
Car: 07 Sti
Default Mounting AccessPort
I know i searched. I want to know what i can do about the Ob2 connector. It hits my leg while i have the accessport plug in. I'm no small guy so im not sure what to do about this. I'm buying a mount today for the accessport. What can i do about the connector sitting out?
new2subaru! is offline   Reply With Quote
Old 06-19-2008, 08:12 AM   #2
Car: 05 WRB STi
Fav Mod: PWT points.
Default Re: Mounting AccessPort
nothing that I know of. I tie the line up behind the box underneath the dash so it doesn't hang down. Just use a zip tie and attach it to one of numerous wire bundles underneath. But as far as the box goes, unless you want to do an extensive relocation of the obdII port itself, there is nothing that I know of...
Old 06-19-2008, 11:12 AM   #3
Car: Blue 08 WRX STi
The part that you plug the dongle into snaps out of the metal bracket by pushing a couple clips, then just zip tie it up out of the way once your connected
BlueSubaru is offline   Reply With Quote
Old 06-19-2008, 11:45 AM   #4
Car: 07 Sti
sweet thanks for that. Also:Mounting AccessPort - NASIOC
Old 06-19-2008, 02:07 PM   #5
Car: 04 PSM STi
This might work - an extension cable with right angle connector.
wi77iam is offline   Reply With Quote
Old 06-19-2008, 02:40 PM   #6
Car: 05 WRX STI OBP
Fav Mod: factory shift light!!! beep beep
Originally Posted by wi77iam View Post
nice find dude
