Old 06-18-2008, 06:11 PM   #1
Car: cgm 05 wrx sti
Fav Mod: 20g
Default Can somebody help me??
TimeA/F Correction #1 (%)A/F Learning #1 (Current)* (%)Atmospheric Pressure (psi)Engine Load (Direct)* (g/rev)Engine Speed (rpm)Feedback Knock Correction* (degrees)IAM (Ignition Advance Multiplier)* (multiplier)Ignition Base Timing* (degrees)Ignition Timing Advance* (degrees)Injector Duty Cycle (%)Intake Air Temperature (F)Knock Correction Advance (degrees)Manifold Relative Pressure (psi)Mass Airflow (g/s)Throttle Opening Angle (%)Vehicle Speed (mph)07.810.812.191.07199800.626.772.387.771152.51.636.2340.78273756.250.812.191.09206100.626.752.428.051152.52.0338.2944.31277503.91012.191.12213500.626.622.398.321152.52.3240.8145.882711096.25012.191.16223400.625.552.519.051152.52.7644.0351.762914840012.191.22233100.8524.993.939.9611543.3448.2380.782918430012.191.2824170124.314.7210.9211553.9252.7894.93122180012.191.3525420122.394.9212.0211554.559.341003225780012.191.4226720121.084.9212.9511555.2265.291003229530012.191.5227720118.555.5114.981155.56.0973.861003533120012.191.7129370114.975.6518.541155.57.488.51003736720012.191.9630500110.965.6222.631155.59.58106.431003940470012.192.193222019.244.9327.67115512.33122.911003944060012.192.373401018.644.9232.39115514.95141.11004147810012.192.533556017.984.9235.37115517.41153.511004451560012.192.583788019.25.2337.41155.518.43166.451004755150012.192.6539440110.415.3338.631155.518.43168.621005058900012.192.641930111.715.3242.3115418.43183.891005062500012.192.6543050112.315.0243.791173.518.43192.321005366250012.192.6645460113.864.9247.05117218.14205.191005769840012.192.6347450116.524.9247.971170.517.85208.141006073590012.192.6548710117.124.9249.11170.517.56217.521006077180012.192.650480117.494.9250.9117217.12221.391006380930012.192.5952540117.764.9251.571180.517.12225.271006784680012.192.5453900118.664.9253.761180.516.83230.471007088280012.192.51554600.619.454.9253.941180.516.4232.261007391870012.192.48571700.120.270.4956.681180.516.25236.661007395620012.192.44584800.120.760.4956.131180.515.82237.571007699220012.192.41603400.121.320.4957.151200.515.82241.5310080102970012.192.37612100.122.110.4658.261200.515.67241.9810082106560012.192.33631200.122.720.4158.051200.515.53243.310082110310012.192.29639800.123.370.3458.741200.515.53245.4710084113900012.042.25657100.123.630.3458.51200.515.24243.2710086117650012.041.11627400.123.9503.931180-3.48163.9511.7689121250012.040.61546000.123.9503.411200-8.1341.710.9891
kyle1984 is offline   Reply With Quote
Old 06-18-2008, 06:19 PM   #2
Car: cgm 05 wrx sti
Fav Mod: 20g
Default Re: Can somebody help me??
Sorry how do I post a document from excel correctly?
