Old 06-07-2008, 09:30 PM   #1
Car: sti
Default help me identify this ecu please!
So im doing a 06 sti swap into a 05 2.5 RS. The swap i purchashed was suppose to be everything out of a 06. When we got around today to installing the sti stuff, i find the harness is labeled as a 05 sti. and the ecu on one side he wrote 04 sti silver. but on the back side it says 05 sti.
It would be competley awesome if it was a 04, but i need to figure it out so i know what to do about the immobilzer system. it plugs in perfectly to the "05" harness. and i know you have to repin 5 pins for by passing the immobilizer, but my guess is the connectors are the same shape still.
So how do i tell if its a 04 or 05 ecu? heres a picture and the numbers on it. any other help would be great. thanks.
i realise its a little blurry, so heres the numbers.
22611AJ930
112200-8791
12V
Thanks all.
stikindaguy is offline   Reply With Quote
Old 06-08-2008, 04:45 AM   #2
Default Re: help me identify this ecu please!
its an 05
Merchgod is offline   Reply With Quote
Old 06-08-2008, 09:28 AM   #3
Car: sti
how do you tell?
Old 06-08-2008, 12:44 PM   #4
the case id - aj930 - you can do a search at openecu.org. Someone else has already uploaded their rom and also listed their case id, so you know it is an 05.
Old 06-08-2008, 09:11 PM   #5
Car: sti
beautiful, thanks a bunch!
