Old 05-22-2008, 06:01 PM   #1
Car: 07 OBP WRX-STi
Fav Mod: Girl in the backseat
Default cyl #2 misfire?
Do I need to worry? I think the code was p0302 or something but the ap said cyl #2 misfire....I have an 07 so I'm pretty paranoid....
TuffStuff is offline   Reply With Quote
Old 05-22-2008, 06:24 PM   #2
Car: Turd brown 07 STI
Fav Mod: BOV! on stock T-bo!
Default Re: cyl #2 misfire?
misfire on any cly should worry you....i guess i dont know how much money YOU MAKE>.... but subscribed cuz im not sure what that means for cyl #2
Grey Ghost is offline   Reply With Quote
Old 05-22-2008, 06:27 PM   #3
Car: 07 OBP WRX-STi
this was at idle tho...maybe its a clogged injector? the car has a little vibration in it since I beat on it last week and today when I let it warm up the CEL popped up so i cleared it reset the ECU drove it around for a bit till like 40 miles then beat on the car again and now it seems OK like no vibration? Do I have like a dirty injector or something?
Old 05-22-2008, 06:30 PM   #4
I have no clue.. but your power seems low for a 07 protuned stg2 wat psi ..u running?
Old 05-22-2008, 06:44 PM   #5
Car: 07 OBP WRX-STi
19psi on a Japtrix mustang dyno
Old 05-22-2008, 07:05 PM   #6
ok that might explain the power....the mustang dyno is the dyno that reads low numbers right...?
Old 05-22-2008, 07:17 PM   #7
Car: 07 OBP WRX-STi
the power is fine its the misfire im ****tin bricks about lol. Its powerful enough to run with the evos and stis down here.Yea the mustangs are rumored to read low.
Old 05-22-2008, 07:24 PM   #8
tru hopefully these bumps will get you some info
Old 05-22-2008, 07:28 PM   #9
Car: 07 OBP WRX-STi
yep..lol
Old 05-23-2008, 05:56 AM   #10
Car: 07 OBP WRX-STi
bump for help...
Old 05-23-2008, 06:02 AM   #11
Car: UGM 07 STI
Fav Mod: Learning to drive better
Send a message via AIM to Urban07STI
May have foiled a plug. When doing a compression test on my buddy's 07 with him, spark plug was cracked unknown to us then after reinstalling plugs and going out driving, he popped a CEL. Swapped in an extra plug I had and all set.
Urban07STI is offline   Reply With Quote
Old 05-23-2008, 10:31 AM   #12
Car: 07 OBP WRX-STi
sweet! If it acts up again I'll check the plugs
Old 06-04-2008, 08:01 PM   #13
Car: 06 Subaru STi
Fav Mod: ....
I know this may be a little late, but at one time I was getting a misfire on #1...kinda freaked me out until I talked with Scott Seigel at TopSpeed...I was setting up a Protune with him at the time.....anyway, he was almost willing to bet money that it was the injector...it seems the stock ones aren't really known to be completely trouble free on some of our cars...and, as additional food for thought, I run a bottle of injector cleaner through the car every oil change...no more misfires.....I did forget to one time and about a month later, guess what...misfires....just figured I'd throw that out there....
SlobberJaw is offline   Reply With Quote
Old 06-05-2008, 03:10 AM   #14
Car: 2006 WRB Subaru Impr
Fav Mod: Element Tuning GT52
I wouldn't be too worried about. Just keep an eye out for it if this problem replicates. I have had numerous cylinder missfires in the last 10 months or so. I was told that it was aftermarket fuel injectors and it will happen from time to time.
Clark_Kent is offline   Reply With Quote
Old 06-05-2008, 08:31 AM   #15
Car: 06 Aspen/gold STi
Fav Mod: Whatever I buy next
i wouldn't say you dynod too low either, 313whp is not a bad power number for stage 2 07 or not.
C.J. is offline   Reply With Quote
