Old 05-16-2008, 07:32 AM   #1
Car: 06 Subaru WRX STi
Default Limp mode parameters?
My ecu fiddling stops at this one but maybe someone can help are the parameters of limp home mode adjustable? There is talk in this thread about using the test connector line as a failsafe instead of just running boost cut or aftermarket ems like utec or hydra with map switching I am new, so go easy... - NASIOC .
But i dont think the stock parameters would fully keep you safe without some adjustments.
Old 05-19-2008, 08:35 PM   #2
Default Re: Limp mode parameters?
No ideas? well then lets switch to if you had to make a limp mode to not explode an engine on meth fail what would be the best way.
