Old 05-11-2008, 05:02 PM   #1
Car: 07 Subaru WRX STi
Fav Mod: Stage 1 (for now)
Default AP Live data information
With the new firmware, there's more live data categories than before. Can someone chime and explain what these mean, and what the optimal range is for those specific categories.
Injection Pulse Width
Mass Airflow
Battery Volt
Calculated load
Dynamic Advance Mult.
Ignition Advance
Learned Ignition
WG Duty
MAF Voltage
Fuel Trim (short and long)
Lastly, are there limits to the AP readout (e.x AFR never reads lower than 11.0 at WOT...is this the true # or does the AP just not register les than 11?) Is the Boost meter accurate (since I'm using this as my primary boost gauge)?
STiProsDoc is offline   Reply With Quote
Old 05-13-2008, 09:22 AM   #2
Car: 07 obp sti
Fav Mod: endura-tech's
Send a message via AIM to sti* fan
Default Re: AP Live data information
anyone??
sti* fan is offline   Reply With Quote
Old 05-13-2008, 09:38 AM   #3
Car: '05 CGM STi
Fav Mod: Cracked VF39
Can't really provide any answers but instead point you in the direction of the romraider forums. That is, if you really want to know... bring your reading glasses.
deegee is offline   Reply With Quote
Old 05-13-2008, 11:13 AM   #4
Car: 07 obp sti
thanks ill look into romraider..
Old 05-13-2008, 04:57 PM   #5
LSE
Fav Mod: Defi Gauges
a lot of the timing stuff will change based off load, boost, throtle, temperature..etc etc. too many variables to give you a range. I mean just look at it. It's all over the place. Normally you want to graph these over a pull and compare with another pull. Just staring at it in the ap makes no sense.
