Old 05-11-2008, 08:58 AM   #1
Car: Blue 06 WRX STi
Red face N00b question about Cobb AP
For Stage 2 , does the Cobb Ap work fine with downpipe cat back and CAI?
sorry i am new and wanted to know if CAI is supported with Cobb AP ..as i've read stage 2 is TBE or downpipe and catback ?? is this correct? wasn't sure with CAI if something else needed or if all good with cobb ap ?..i apologize if this is obvious....are there options or something on the cobb ap that you chose when programming??...thanks again for any input
scotianmotion is offline   Reply With Quote
Old 05-11-2008, 01:29 PM   #2
Car: 06 WRB STI
Fav Mod: Maddad DP/Borla XR-1 Turboback
Default Re: N00b question about Cobb AP
"stage 2" is considered downpipe and a your AP. catback is not necessary but recommended. if you do some searching you should find that a cai may be more beneficial with a protune.
minorthreats is offline   Reply With Quote
Old 05-11-2008, 01:30 PM   #3
HowTo Contributor
Fav Mod: Stg 2 - STRI gauges
Dont use any intake w/ stage 2 off the shelf, you need a freer flowing downpipe, but in the map notes it tells you to use the OEM air box
Old 05-11-2008, 02:09 PM   #4
Trader Rating: (15)
On the ap you can choose you're octane, and stage map. exm..stage1, stage2, stage1-91oct, stage2-91oct...stage1-93oct, stage2-93oct. both of which have an acn option(arizona,california, nevada). which are speficic for those states. Good lcuk!
Old 05-11-2008, 04:57 PM   #5
Car: 07 Subaru WRX STi
Fav Mod: Stage 1 (for now)
So Stage 2 map will work with a downpipe alone? Catback isn't needed? The map notes say "to be used with TBE".
STiProsDoc is offline   Reply With Quote
Old 05-11-2008, 05:02 PM   #6
Car: SWP 07 WRX STI
Fav Mod: Seatbelt Ding Disabled
it is not needed, but highly recommended because the stock cat does yeild power. i am in the same market as you are, i will soon be purchasing a TBE + AP
tb202 is offline   Reply With Quote
Old 05-11-2008, 05:28 PM   #7
HowTo Contributor
yeah a TBE is highly recommended, but there are people running the OEM catback.
Old 05-12-2008, 08:25 AM   #8
sorry for probably a stupid question ...but do you have to do a stage 1 b4 doing a stage 2 ..or can you just go right to stage 2 providing you have proper setup....i'm assuming you can go right to stage 2 ..just wanted to confiem
Old 05-12-2008, 09:18 AM   #9
rgt
Car: 07 WRX STI WRB/Gold
Fav Mod: COBB AP Stage 2 93 oct v1.04
Install the downpipe and/or exhaust and flash to stage 2. Stage 1 is not required before stage 2.
rgt is offline   Reply With Quote
Old 05-12-2008, 10:19 AM   #10
thanks for info
