Old 05-09-2008, 01:42 PM   #1
Fav Mod: Fujitsubo!!!!!!!!
Default COBB Stage2 can't set the LC rpm
Heya,
So I updated my firmware today and I decided to load up the LC map.
The thing is, I can't seem to be able to set the RPM Lauch Control via the AccessPort. It says it's not part of the map (or go download the appropriate map).
The Flat Foot RPM setting is working fine ...
What's wrong?
Thanks,
Sincerly
Marc-André
Rennes is offline   Reply With Quote
Old 05-10-2008, 07:22 AM   #2
Default Re: COBB Stage2 can't set the LC rpm
Anyone? I'll e-mail COBB I think.
Old 05-10-2008, 07:34 AM   #3
Car: '05 Aspen White STi
Fav Mod: EQ Tuning tune
Originally Posted by Marceau View Post
Heya,
What's wrong?
Thanks,
Sincerly
Marc-André
Don't you set the rear defroster, push in cruise control, give it gas until it hits the LC, raise it up with the cruise/gas, then when it gets to where you want push up the cruise 3 times, then go back to idle and turn off the rear defroster? I'm pretty sure that is what I did and it works fine.
Old 05-10-2008, 07:40 AM   #4
Fav Mod: DRL Delete
Does the LC work at the default 4000? Have you watched the video on how to set it? I would send you the link right now but I'm on my iPod Touch right now. I think you adjust the LC and FFS with the cruise control. Be careful on this map, it's cool but hard on your ride.
STI Dy is offline   Reply With Quote
Old 05-10-2008, 07:48 AM   #5
Fav Mod: DRL Delete
I just read your post again. I think I know what's going on. If you updated your AP firmware re-download all the maps you use. After you you have done that reflash with the new map.
Old 05-10-2008, 11:00 AM   #6
@Importfanatic17
With the new version of the software, you can set both these setting in the ECU SETTINGS options Sadly, only one works for me and it's not the LC.
@STI Dy
Correct. I'll download the new maps and try again.
Thanks,
Old 05-10-2008, 03:42 PM   #7
Nope same thing. Same problem. Can't set the LC but I can set the FT.
Old 05-12-2008, 04:17 AM   #8
I'll let you know once I have a answer from COBB.
So far, I've tried reflashing AND realtime flashing and same results, only the FFS is working and not the LC.
I'm starting to think this might be a bad firmware or something ... I don't know ... we'll see.
