Old 05-09-2008, 07:19 AM   #1
Default Cobb Ap Question
my car was recently broken into and they stole my ap2 from the trunk. i know it isn't the best place to keep it but who knew it would get broken into that night. i had just finished installing the stg 2 map earlier. what are my options of retrieving my stock map? the stealership? also, i was planning on going gt30 this summer,if i get a new ap will it recognize the cars ecu since the stock map isn't loaded? im so frustrated.... any input is greatly appreciated! cheers - sorat
SiamSti is offline   Reply With Quote
Old 05-09-2008, 08:11 AM   #2
Car: '05 CGM STi
Fav Mod: Cracked VF39
Default Re: Cobb Ap Question
Dunno about getting your stock map. I guess the stealership perhaps?
But yes, if you get a new AP it will recognize. For instance, if you purchase a used car that hasn't been unmarried from it's previous AP, you can overwrite.
deegee is offline   Reply With Quote
Old 05-09-2008, 12:24 PM   #3
Car: OBP 2007 STI
Fav Mod: Brake dust
Cobb has a stock mode map on their site. I assume it's exactly the same as factory map.
Kamrulz4ever is offline   Reply With Quote
Old 05-09-2008, 12:27 PM   #4
Car: 2007 WRB Blue STi
Fav Mod: COBB!
Send a message via AIM to mond12345
Yeah they do but he has no way of getting to his ECU....
mond12345 is online now   Reply With Quote
Old 05-09-2008, 12:41 PM   #5
Car: OBP 2007 STI
Fav Mod: Brake dust
Another AP should override the previous tune. I'd contact cobb to make sure that will do. If nothing works, I guess you can go opensource and use the stock parameters. You'll have to find the stock parameters from somewhere else in that case.
Old 05-09-2008, 02:49 PM   #6
thanks for response guys, very informative....ugh. outta curiosity what alarm setups are you guys running? apparently ours aren't that great.
