IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > ECU Tuning & Performance Electronics
Old 05-01-2008, 09:38 PM   #1
Car: black 05 wrx sti
Default enginuity
this is probably the stupidest question but does reseting the car by disconnecting the battery get rid of the reflash? cause i was driving and accidently had the dccd all the way to the back and a cel and cruise blink came on..i pulled over and reset my battery....cel went away and was just wondering if is reset the ecu back to the stock tune
blazinmr2 is offline   Reply With Quote
Old 05-01-2008, 09:44 PM   #2
Car: 02/04/08 WRX/STi
Fav Mod: EcuFlash - of course!
Default Re: enginuity
No. EcuFlash writes the nonvolatile flash memory of the CPU in the ECU. These changes stick until you modify them again. The RAM of the CPU in your ECU however, loses its contents when you disconnect the battery. This RAM contains many parameters which the ECU "learns" during the course of running your engine. It also stores CEL data here. So when you start driving the car again after disconnecting the battery, you should expect it to run a little differently for a while. The same is true when you reflash the ECU, because the reflashing program is put into the RAM which also wipes out this learned data.
Colby
colby is offline   Reply With Quote
Old 05-01-2008, 09:50 PM   #3
oh ok thank you for the info, by any chance would you know how long it should take to being the same again?
Old 05-02-2008, 10:16 AM   #4
Car: '07 STi Limited #482
1-2 weeks IMHO. People say all kinds of different things, but for my tunes, after a solid week, things feel so much like they should I cant tell.
