Old 04-30-2008, 07:37 AM   #1
Default CEL on & Cruise Flashing
My CEL Stay solid while the cruise control light is flashing.
No code was found with my Access Port I, but I was unable to reset code off with my Access Port, it says unable to communicate with ECU.
Anyone know what the CEL/cruise problem I am having?
Also, can I remove a fuse instead of disconnecting the battery to reset the ECU?
I tried reset the ECU with the key in or out, and I also tried with the green plug plug-in and out.
Thanks
Old 04-30-2008, 07:52 AM   #2
Car: 04 sti
Fav Mod: enginuity tuned
Default Re: CEL on & Cruise Flashing
go to your local autoparts store and borrow their obd2 diagnostic reader...
Old 04-30-2008, 08:03 AM   #3
Thanks.... I made a mistake on my AP on reset thinking it didn't....well...it's early morning for me, as I don't normally get up until another hour, but work early this morning..! Anyway..the reset seems to have fix the problem for now...I'll keep an eye on it..! I am gonna do some logging my street-tuner this weekend...!
Old 04-30-2008, 08:17 AM   #4
I shoud have searched first..but I guess I was abit too worry..! Anyway.., I have read all the posts related to this topic.., here are a few more questions..
1> If the access port isn't find any code, doesn't it means the OBDII scanner should pull any code either?
2> Looks like teh CEL+Cruise flashing can mean many diff. problems.., I am kind of thinking if it is a real issues.., then why does it happen more often to people when starting the car in the morning, but not while they are driving
EL
Old 04-30-2008, 08:44 AM   #5
Car: 04 WRX STi
Send a message via Yahoo to highmark
Added note: If your Cruise light is flashing when the Check Engine light is on it's not bad; Cruise is disabled when the Check Engine light comes on.
highmark is offline   Reply With Quote
