Old 04-27-2008, 07:08 PM   #1
Car: '06 WRB STI
Fav Mod: the girl turn-on feature
Default access port problem....PLEASE HELP!!!!!!!
ok i bought my 06 sti used from a dealer and i was going to try out my friends ap because he is selling it and it said that my ECU could not be remapped because my car had already been tuned with an ap.....we double check his to make sure it still wasnt on his car and everything was normal....is there anyway i can reset the ECU by myself or can Subaru do it or what???....PLZ HELP....thanks in advance.....!!!
appletree is offline   Reply With Quote
Old 04-27-2008, 07:23 PM   #2
Car: Black 07 WRX STI
Fav Mod: AP
Default Re: access port problem....PLEASE HELP!!!!!!!
call COBB!
STUKA is offline   Reply With Quote
Old 04-27-2008, 07:48 PM   #3
Car: 06 Subaru WRX STi
did you click uninstall from his car before using it on your car.
halfelite is online now   Reply With Quote
Old 04-27-2008, 08:42 PM   #4
I'm Jim Halpert
Fav Mod: Ricer Flyby
his car already has a flash on it aparently
Old 04-27-2008, 09:28 PM   #5
Car: UGM 07 STi
Fav Mod: Cobb DP and Stg2
Make sure you properly unmarried it from his car, we need more info!
Hirogen is offline   Reply With Quote
Old 04-28-2008, 06:04 AM   #6
Car: '06 WRB STI
yeesss.it is properly unmarried from his car...it said my ECU has already been reflashed with an access port..i jsut want my own accessport so "I" have the control over my ECU
Old 04-28-2008, 06:12 AM   #7
Car: 05 WRB STi
Fav Mod: PWT Points
If you have a map loaded from another accessport then you are f**ked. You would need that accessport to change anything, including unmarrying the map from your ECU. I would suggest calling cobb and see what they can offer. I bet you will probably have to send in your ECU however. Good luck.
Old 04-28-2008, 01:33 PM   #8
Fav Mod: Gram Light 57F's
Send a message via AIM to jordanretro1223
Yeah sounds like whoever the previous owner was flashed the car and thats why you can't flash now with your AP. I'm guessing like rmo55c that you'll have to send in the ECU to Cobb. They should be able to fix it so you can flash.
jordanretro1223 is offline   Reply With Quote
