Old 10-30-2008, 01:07 PM   #286
Car: 08 aw sti
IWSTI Addict since: Jun 2008
Default Re: disabling hill-start assist....?
I do not want a warning light.
I do not want the feature.
nuff said.
nbudros is offline   Reply With Quote
Old 10-30-2008, 01:57 PM   #287
Fav Mod: Xpel Clear Bra
IWSTI Addict since: Aug 2008
I'll try that 09 method on my 08 too. I doubt it'll work but it's worth a shot.
STi413 is offline   Reply With Quote
Old 12-01-2008, 06:20 PM   #288
Car: LR 08 STI
Fav Mod: Cobb Stage 1
IWSTI Addict since: Dec 2006
This will be a rant, don't read if you are easily offended.
I just discovered hill start assist (and this thread). Read the whole thing. Looks like my lack of research and extensive test driving has screwed me. I was really digging the car until today. Now I don't even want to drive it. I never imagined Subaru would put in such a badly designed and intrusive feature such as this.
Intrusive in that it takes over/interferes with the driving experience.
Badly designed in that it can't be disabled (in 08's), can't be adjusted, and delays the safe movement of the car one full second.
I was waiting in a long line to merge. It is an onramp I take from time to time but never again apparently. Was my turn to go at the yield sign, heavy traffic, saw my spot, tried to pop the clutch and go. Bam killed the engine. This is not what an STI should do. This is not what any manual transmission car should do. I like being able to pop the clutch and go when I want to go. That is why I drive a manual transmission car.
If I can't get used to this and learn to live with it in the next couple months, or a fix/disable doesn't become available for the 08's. I will seriously trade this car in.
Which would suck really bad because I wouldn't be able to afford an early trade in again and would have to step down into something way less sporty.
But at least the brakes wouldn't lock themselves when I am waiting to merge on that onramp.
I hate my car right now. Please no one take this personally. I am not trying to start a fight, just venting how I feel.
Old 12-01-2008, 07:10 PM   #289
Car: Silver 08 STI
IWSTI Addict since: Apr 2008
I felt the same way when I got my car last jan/feb. its not just subaru, google bmw hill start, hill holder etc and you will find the same rants. trust me you will get used to it in time and maby even appreciate it. in the mean time lift the handbrake until the HB light comes on and the HSA is disabled. when I'm lazy, I just set the HB to the first notch and then drive off then release the handbrake (brake not set at first notch)
cheers and enjoy your car
jrdriller is offline   Reply With Quote
Old 12-01-2008, 07:12 PM   #290
Car: 06 sti wrb
Fav Mod: trading the svt for an sti
IWSTI Addict since: Nov 2005
Originally Posted by kailua View Post
Ok, scanned the pages from my 09 owner's manual. My scanner is pretty crappy so it might be hard to read. This is for a US STI.
any canadian in here that tried it on his 09 sti??
the ambush is offline   Reply With Quote
Old 12-01-2008, 07:37 PM   #291
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
I'm looking into the issue to see if there is a firmware update for the VDC CM that would allow us to disable hill-assist. I'm not sure if it would be possible or not to update the VDC CM via Subaru Select Monitor or some other device.
I'll keep you posted.
Old 12-01-2008, 08:06 PM   #292
Car: LR 08 STI
I just emailed SOA. Hope I get a response.
Old 12-02-2008, 08:09 AM   #293
Car: 08 STi -Blue
I went to the dealer in Plano and they said they could do nothing with it. That is BS
Subaru needs to give us a fix for this.
Booster Boy is offline   Reply With Quote
Old 12-02-2008, 08:22 AM   #294
Car: 08 Subaru WRX STI
IWSTI Addict since: Jun 2007
Send a message via AIM to RAE129
MSPT any word? Anyone else have any luck with the 08?
RAE129 is offline   Reply With Quote
Old 12-02-2008, 08:23 AM   #295
Car: 09 SWP STI
IWSTI Addict since: Oct 2006
yes, the manual shows you how to disable it, but disabling the hill assist leaves a stupid "your hill assist has been disabled" symbol light on =(
jonnyboi is offline   Reply With Quote
Old 12-02-2008, 10:41 AM   #296
Car: DGM 08 STi
IWSTI Addict since: Sep 2008
I talked to the tech at my dealer about seeing if there was some way of updating the VDCCM. He said he hadn't heard of anything, but would call his service rep. I never heard back from him and haven't bothered to call him back since he was pretty much trying to blow me off. You'd need to chat with someone at Subaru who knew how the VDCCM was programmed. Is it flash programmable or does it require a chip swap? Hopefully you have some inside people cause I've just gotten the run around. I sent an e-mail to SOA and was told to call them. The rep told me hill-start assist could not be disabled. This was right before the 09 came out with its disable feature. I debated contacting the TSB since this could be considered a safety issue if the car stalls while you're trying to go through an intersection, but decided it wasn't worth it. Click the handbrake one notch at the light then release it once you get going.
David
DavidM17 is offline   Reply With Quote
Old 12-02-2008, 10:52 AM   #297
Pre
Car: '08 STi
IWSTI Addict since: Feb 2007
Let's picket SOA. Who is going to make the signs?
Pre is offline   Reply With Quote
Old 12-02-2008, 11:44 AM   #298
Car: 97 gc8
IWSTI Addict since: Sep 2003
the hill assist is inside the abs pump so there is no fix for it..let me tell you i tried lol..i have yet to see a 09 sti so im not sure if there is a change
dave/mspt
M.S.P.T is offline   Reply With Quote
Old 12-02-2008, 12:27 PM   #299
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
dave/mspt
Yes but there is some programming in the '09s that allow it to be disabled. I'm not sure if it is a message on the CANBUS to the ABS CM or to the ECU then to the ABS CM.
Old 12-02-2008, 12:40 PM   #300
Car: 97 gc8
there is nothing in the select monitor to disable it...
dave
