Old 10-24-2008, 01:19 PM   #241
IWSTI Addict since: Apr 2008
Default Re: disabling hill-start assist....?
Originally Posted by mapleleaf View Post
Stop your vehicle in a flat area, apply parking brake and turn engine off.
Restart engine.
Press VDC button and hold until disabled.Do not take finger off the button.
The light will go yellow, green and it will turn off.
Within 5 seconds of of VDC light turning off, release the button.
Within 2 seconds of releasing button, press the VDC button again and and a hill assist light will illuminate on the dash.
Turn off engine.
Restart engine.
Presto!
You all owe me beer
WOW! If this works we can finally close this thread!!! A lot of people will be really happy to read your post. Thanks in advance. But a few questions, are there directions for turning HSA back on? Does it just turn off for that restart or until you reverse it?
Halogene is offline   Reply With Quote
Old 10-24-2008, 01:26 PM   #242
Car: 2009 STI-Dirty White
Fav Mod: Driver
IWSTI Addict since: Jun 2007
Until you reverse the procedure.
It can also be adjusted by the dealer for sensitivity.
mapleleaf is offline   Reply With Quote
Old 10-24-2008, 01:31 PM   #243
Fav Mod: Driver
Sticky it
Old 10-24-2008, 01:49 PM   #244
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
I just tried it and it doesn't appear to work on the '08. Something weird does happen though:
- I started the engine
- Pressed and held the VDC button; it went yellow, then 2 seconds later green. I continued to hold it and the VDC light turned off.
- I released the button within 5 seconds.
- Pressed the VDC button again and the hill-assist light did not turn on. The weird part is that the VDC button appeared to stop working. I could no longer turn the VDC on and off (I confirmed this the second time I tried it, not the first).
- Turned off the engine.
- Restarted and tried to roll out of my garage, which has a very slight incline. Hill-assist activated.
Old 10-24-2008, 01:51 PM   #245
Fav Mod: Driver
I will double check the method.
Try having the engine running, apply parking brake and turn off, than restart.
You must confirm once you restart that the VDC off light does NOT illuminate, the abs light does NOT illuminate and that the brake system warning light DOES illuminate.
Do not release the VDC button until the VDC icon disappears. Again, you have 5 seconds to release the switch.
Within the two seconds of releasing just hit the VDC switch once.
Turn off engine, restart engine.
Old 10-24-2008, 02:24 PM   #246
Car: 08 WRB STi
Fav Mod: ditching the cats
IWSTI Addict since: Apr 2005
Restart engine.
Turn off engine.
Restart engine.
Presto!
You all owe me beer
If this works on the USDM then I will gladly buy you a beer!!
Old 10-24-2008, 02:36 PM   #247
Fav Mod: Volk RE30's and 255-35 Dunlop Z1's
IWSTI Addict since: Sep 2006
Restart engine.
Turn off engine.
Restart engine.
Presto!
You all owe me beer
Thanks.
ploney is offline   Reply With Quote
Old 10-24-2008, 03:07 PM   #248
Fav Mod: Driver
Anyone try it?
I just confirmed the procedure on my car again.
I hope it works for you.
Old 10-24-2008, 03:12 PM   #249
Car: 08 STi -Blue
IWSTI Addict since: Aug 2008
I just tried it several times. No cigar
Booster Boy is offline   Reply With Quote
Old 10-24-2008, 03:25 PM   #250
Fav Mod: Driver
****ty guys
Must be an 09 feature only.
I'm still sure that the dealer can remove the feature or make it less aggressive.
I'm going to see my friend tonight to work on our RallyX car, I'll try to get more info.
Hill assist truly does suck ass.
Old 10-24-2008, 04:42 PM   #251
Super Moderator
Car: 08 DGM STI
Fav Mod: My wife :)
I'm going to contact Subaru Canada and see if this feature exists already on the '08 but is "undocumented" or perhap it requires the dealership to do it. I have a feeling it might even be a firmware upgrade on the VDC control module, but who knows if they would do this or not.
Old 10-24-2008, 04:52 PM   #252
Fav Mod: Driver
I'll try to get some more info.
Old 10-24-2008, 05:55 PM   #253
Car: AW 08 STi,PSM 02 WRX
Fav Mod: More Powa!!!!
IWSTI Addict since: Sep 2008
Why can't this work for the 08's? I got all excited for nothing! Do you know what happens when someone gets all excited for nothing? Blue balls!
Colombo is offline   Reply With Quote
Old 10-24-2008, 07:20 PM   #254
Fav Mod: Driver
Rub some gold bond on them
Old 10-24-2008, 09:18 PM   #255
Car: 08 aw sti
IWSTI Addict since: Jun 2008
I just tried and got nothing as well... this would explain why I stalled in the driveway today... 1 foot devent incline (scrapes if not done right)
Also I was under the impression if u hill assist engages taping the break disengages it. Also let go of the break before you start your routine it works fine, no assist.
I live in texas our non busy hills are limited... Ill see what I can find out..
nbudros is offline   Reply With Quote
