Old 04-21-2008, 05:04 PM   #1
Car: 04 WRX 'blk prl' STi
Fav Mod: Injen CAI w/ used filter :D
Default TXS STi UTEC
Hey all.
I've recently come into posession of TXS STi UTEC (pulled it out from a totaled 05 STi ). Anyone using it satisfied??? Any suggestions, cautions, tips, w/e, are apprecited. Thanks.
sti_schumacher is offline   Reply With Quote
Old 04-22-2008, 02:22 AM   #2
Default Re: TXS STi UTEC
Do not just throw it in the car and drive. Install it and then go to the TXS site and grab the base map and parameters files and load them up. You might all so want to make sure you have the latest firmware loaded too.
TheMadScientist is offline   Reply With Quote
Old 04-28-2008, 04:48 PM   #3
if i replace the stock exahust to a catless bellmouth 3" DP and a 3" TBE and install the UTEC (with the maps set to 'stage 1 - stock'), will i be able to avoid o2 sensor lights?
Old 04-29-2008, 05:13 AM   #4
can i manage the O2 sensor range with this UTEC?
Old 04-29-2008, 12:36 PM   #5
Car: blue 04WRX STi
Send a message via AIM to adholliday
- if you run a turbo-back exhaust you should use the stage 2 map from TXS, the sti's are weird about the CEL coming on with catless exhaust.. i have the TXS TBE with 4" DP and catted midpipe and i havent had trouble.. my friend has the catless DP and he hasnt had problems running stock
- you cannot adjust the range of the O2 sensor with the utec (or any other computer that i know of) a stock spec. oxygen sensor has a very narrow range of sensitivity, that's why it's suggested to go with a wideband O2 for advanced tuning
adholliday is offline   Reply With Quote
Old 04-29-2008, 02:47 PM   #6
With open source you can adjust the Iout vs AFR.
Old 04-29-2008, 04:59 PM   #7
i have absolutely on idea what you said here....
Old 05-01-2008, 08:24 PM   #8
the DP i plan to purchase has a cel fix. That should work too, correct?
