Old 04-14-2008, 08:32 AM   #1
Car: UGM 07 STI
Fav Mod: Learning to drive better
Send a message via AIM to Urban07STI
Default Datalogging on Mac OS X
I did search for this but could not find the topic I was looking for....I have a new Macbook (love it) and wish to start datalogging with it. I am only running OS X (no VMware or bootcamp with windows). Can this be done? Also, I have a Cobb AP2.
I swear I remember seeing if somewhere that you can use the AP2 with a mac and also datalog using the AP cable.
Any advice/suggestions would be great, thanks!
Urban07STI is offline   Reply With Quote
Old 04-14-2008, 08:54 AM   #2
Fav Mod: Cobb AccessPort Stage 1
Send a message via AIM to hairlesswookiee
Default Re: Datalogging on Mac OS X
i would also like to know this... i dont want to install windows on my apple just so i can use AccessPort. if there is another alternative i'd appreciate it.
~i think i'm gonna check out Cobb's forums for this too.
hairlesswookiee is offline   Reply With Quote
Old 04-14-2008, 09:00 AM   #3
I has BOOST!
Fav Mod: LightWerkz Projector Retrofit
Trader Rating: (12)
Send a message via AIM to MacSTi
All that is out at this time is the Map Manager Software in Beta for Mac OSX, that is all that is offered at this time from Cobb.
AP Manager for the Mac - BETA - COBB Forums
MacSTi is offline   Reply With Quote
Old 04-14-2008, 10:42 AM   #4
Car: UGM 07 STI
So does that mean no datalogging? Somewhat confused....
Old 04-14-2008, 11:44 AM   #5
Car: 04 WRX STi
Send a message via Yahoo to highmark
If your simply interested in data logging; can't you use Enginuity via your Apple to log?
highmark is offline   Reply With Quote
Old 04-14-2008, 11:47 AM   #6
Car: UGM 07 STI
No idea......? That's why I'm asking.
All I want to do is datalog and put the data on my mac.....Do I have to buy the tactrix cable or can I use the AP2 cable?
Old 04-14-2008, 11:51 AM   #7
Car: 04 WRX STi
I know a Tactrix cable will work; I know nothing about COBB.
Old 04-14-2008, 12:12 PM   #8
Car: white 04 sti
this is prolly something you dont want to hear... im running a macbook with xp using a utec datelogger program i got from the net... it basically lets u datalog all the info from the utec and datalog all the info from your wideband. I think the same company that makes the software i use makes it for the cobb accessport as well. the only thing that sucks is u have to run 2 serial cables that convert to usb 2.0 since our lovely macs do not have serial ports.
andypaintguns is offline   Reply With Quote
Old 04-14-2008, 12:16 PM   #9
Car: UGM 07 STI
Well I ordered a tactrix cable....should be good although might have to get some connector device.....I dont think my macbook has a serial port?
Old 04-14-2008, 12:24 PM   #10
Car: 08 STi, SSM
my tactrix cable is usb
Old 04-14-2008, 12:40 PM   #11
Car: UGM 07 STI
Oh perfect, I should be all set then, hopefully datalogging by the end of the week.
Old 04-14-2008, 03:41 PM   #12
Car: 08 White STI
Good luck getting it to work on the mac. I ****ed with it for about 2 weeks with input from several engenuity/tactrix developers and gave up. The mac will simply not talk to the cable for some reason. EcuFlash comes with its own FTDI drivers for USB to Serial, but they are very iffy. Engenuity for some reason is not compatible with these drivers on the mac, so you can download some, however when you install the other FTDI drivers for it, the first ones no longer work. The ones that you can download conflict some how, they also dont work for the reason that you downloaded them for in the first place. I know all of this is not what you want to hear, but install XP on the boot camp and everything works perfectly. By all means try to get it working on the Mac, but it will not work. Even though the program runs the cable simply isnt compatible with Mac. There are also other quirks in the software on the mac that arent present on the PC such as only being able to open one map at a time for editing on the mac, but you can open multiple maps on the PC.
rjacobs is offline   Reply With Quote
Old 04-14-2008, 07:13 PM   #13
Car: RBP 05 2.5RS Wagon
Fav Mod: Group N Lateral Link Bushings
At the moment, the only logging solution for the Mac is to run a Virtual Machine on it with Windows XP.
It really pisses me off that the Mac version of RomRaider works so poorly, but I'm not a good enough programmer to do anything about it.
williaty is offline   Reply With Quote
Old 04-14-2008, 07:39 PM   #14
Car: 06 Subaru WRX STi
It took me a long time to get the osx version running and even then it was not very good would crash all the time sometimes not see the ecu.
halfelite is online now   Reply With Quote
Old 04-18-2008, 08:35 AM   #15
Car: 02/04/08 WRX/STi
Fav Mod: EcuFlash - of course!
EcuFlash works on OSX. If you have any problems let me know at support(@)tactrix.com and I will try to fix them.
Colby
colby is offline   Reply With Quote
