IWSTI.com: Subaru STI Forum
Go Back   IWSTI.com: Subaru STI Forum > STi Technical Discussion > ECU Tuning & Performance Electronics
Old 04-11-2008, 10:38 AM   #1
Community Consultant
Car: 2005 OBP STi
Fav Mod: Learning
Send a message via AIM to CicioSTi
Default Perrin Big MAF ACTUAL Inside Diameter
Who has the down low on the ACTUAL ID of the perrin big maf?
Perrin says that it is 3" ID when you talk to them directly. But almost EVERYONE else says that its 3.25 or around 83mm ID
Anyone know 100% what it is?
CicioSTi is offline   Reply With Quote
Old 04-11-2008, 11:01 AM   #2
Car: 2005 OBP STi
Fav Mod: Learning
Default Re: Perrin Big MAF ACTUAL Inside Diameter???
Never mind...Found it
"The i.d. on the Perrin is 77mm (or 3.0315in) on the inlet side and it necks down to 67mm on the exit side"
I will leave this thread open just for the info though!
Thanks guys
Old 04-11-2008, 11:06 AM   #3
Car: Subaru STI
Fav Mod: Tuning
Send a message via AIM to P&L Motorsports
Measuring one right now, it is 3" ID, 76mm-77mm. I'm just using a measuring tape, so It may be 1mm off or so.
P&L Motorsports is online now   Reply With Quote
Old 04-11-2008, 11:06 AM   #4
Car: Blue 06 Sti
Send a message via AIM to santacruz02
I see most people with just the 65mm, what would the benifit be from upgrading to the 70mm intake lets say if your stage 2
Last edited by santacruz02 : 04-11-2008 at 11:09 AM. Reason: Sorry for thread jack.
santacruz02 is offline   Reply With Quote
Old 04-11-2008, 11:08 AM   #5
Car: 2005 OBP STi
Fav Mod: Learning
Thanks for the verification Ty...appreciate it!
You guys at P&L are awesome!
Old 04-11-2008, 11:09 AM   #6
Car: 2005 OBP STi
Fav Mod: Learning
Stage two you will see no benefit from a bigger intake..the benefit comes when you start maxing out your MAF, then you need to go bigger.
Old 04-11-2008, 11:13 AM   #7
Car: Blue 06 Sti
Ah ok this makes sense! Now with the upgraded turbo inlet like the GMS.. There would be no gain seen either, just a smooth air flow? Sorry now I have defiantly...
Old 04-11-2008, 11:18 AM   #8
Car: 2005 OBP STi
Fav Mod: Learning
Gains would be minimal to none with a stock turbo.
If you want more info on it feel free to PM me.
