Old 04-06-2008, 05:32 PM   #1
Car: 07 WRX STI
Fav Mod: Matching Dead Pedal
Send a message via Yahoo to cpunlamd
Default How Accurate is the Cobb AP Readings?
I down loaded the lastest v1.04 stg2 map from Cobb today and took her for a test drive. My AP reads target boost at 18.4psi and AFR locked at 11.1 @ WOT (in every gear).
Is this possible that the AFR's are locked exactly @ 11.1 in every gear on an OTS map?
How accurate is it really?
cpunlamd is offline   Reply With Quote
Old 04-06-2008, 06:09 PM   #2
I'm Jim Halpert
Fav Mod: Ricer Flyby
Default Re: How Accurate is the Cobb AP Readings?
18.4 is the max the AP will read as far as boost goes so it means you're boosting more than 18.4 in every gear. I dont know about the AFR so i wont comment on that
Old 04-08-2008, 11:03 AM   #3
To clarify, 18.4 psi is the maximum amount the ECU will output. This is not an AP limitation.
parkergc8 is offline   Reply With Quote
Old 04-08-2008, 06:10 PM   #4
Car: 04/08STI 95SVX 86E30
Trader Rating: (53)
Not true. Cobb's software on the V1 AP, not sure about V2, will not display anything higher, but it is possible to read higher than 18.4 off the ECU.
The O2 sensor loses resolution outside of 13.5 or so on the rich side, so 11.1 means nothing.
Tony
Old 04-11-2008, 04:17 AM   #5
Fav Mod: Fujitsubo!!!!!!!!
yeah, my AFR reads 11.1 as well. That's like perfect!
but ... nothing can be that perfect ...
Rennes is offline   Reply With Quote
Old 04-11-2008, 10:23 AM   #6
Car: Silver 05 WRX STi
Send a message via Yahoo to import111
A/F ratio on the AccessPORT is WRONG when you get into positive boost. Anything less than 0psi and the A/F is pretty accurate.
import111 is offline   Reply With Quote
Old 04-11-2008, 10:35 AM   #7
Car: 08 STI,sr20det 510
Fav Mod: boob job for wife
I was hitting 23psi by 3200 rpm with my wategate helper trick and that read on my ap
Old 04-16-2008, 03:50 PM   #8
Car: White 05 WRX Sti
Send a message via Skype™ to josorl
You need a wide band gauge for know the exact mix. The number of 11.1 is only a number that map put on a table but is not real.
josorl is offline   Reply With Quote
