| Junior STI Driver | I'm crossing my fingers that I don't encounter the marginal gains, (even losses in some cases) of my Accessport. I think the fact that my car build date was November, I should have the newer ECU/Code. The coolest part is that I ordered it on Monday, I get it Thursday. 3 month lead time? Bah I say!!! This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Spec C Club Car: 04 STi Fav Mod: GT-35R Location: Colorado Springs Posts: 1,324
IWSTI Addict since: Jan 2003 Trader Rating: (2) | i bet you will love it, i do. i noticed a good gain on stage 1, mostly more boost i think. stage 2 i ran the stock map the other day just to see, it def. feels faster. spool up is much quicker, and it runs more boost also. my egt's are in line with when i was stock. |
| | #3 |
| Junior STI Driver | Good luck, but I agree with cnstman, you will most likely love it. I wouldn't go back to stock--and I am just running stage 1/93 oct. Make sure the base map you use is a performance map--even if it is stage 1/91 oct. Folks had some trouble setting it up with stock as the base map when running the realtime performance maps. This went away when the made the performance map the base map. I am sure you know that already. Cheers and enjoy!!! |
| | #4 |
IWSTI Addict since: Jan 2003 Trader Rating: (2) | i think that with the STi cobb made the "stock" map chage some more stuff so there is no loss of performance if you load it as the base map and then load a performance realtime map, but i wanted to load the map i would be using the most, stage II 93 oct. Cobb did not anticipate so many wrx'ers using the stock map as the base, so they switched it for the STI if i remember correctly. |
| | #7 |
| Senior STI Driver Car: '04 STi Fav Mod: wingless & badgeless Posts: 397
IWSTI Addict since: Feb 2004 Trader Rating: (0) | I just got my ECU back from COBB...and OMFG this car is a beast...coupled with a Vishnu TBE, the car is a rocket. No dyno charts, the nearest one is about 1,000 miles from here. I will take it to the strip, best stock this year was 13.39, so hopefully well into the 12's. |
| | #9 |
IWSTI Addict since: Feb 2004 Trader Rating: (0) | I had a bug in my AP that made my ECU not want to work and had to ship it back to COBB to have them correct it.....excellent customer service from COBB, the best I have ever dealt with in my life... Now I'm at 13.03 ..... so close to 12's!! |
| | #11 | |
| Professional STI Racer | Quote:
| | #12 |
| Spec C Club
Car: 05 GT30R STI Fav Mod: HKS Kansai Diffuser Location: C.A. Posts: 1,155
IWSTI Addict since: Aug 2004 Trader Rating: (8) | drfrink24, Stage 1 AP works great but wait till you go Stage 2... |
| | #13 | |
| Junior STI Driver | Quote:
I've got snowmobile season coming up, that should keep the modding bug quiet. While I mod my snowmobile... ummm... I guess that really just moved it to something else... Its an addiction I tells yah, an addiction!!! This ad is not endorsed by this member. Please register or login to hide this ad. | |
